skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Sun Oct 28, 2007 9:45 am Post subject: 924 turbo |
| Hey, I just picked up a '81 924 turbo. When it is running it leaves a small puddle of oil at the right front side near the cross member. It also is idling pretty high. Supposedly the turbo is not working...I'll get to that soon enough. The clutch peddle is weird, if you start to depress it...it will creep to the floor and stay there...is that a master or slave cylinder problem ? |
Posted: Sun Oct 28, 2007 2:02 pm Post subject: |
The turbo is in the lower front right corner, the slave cylinder is on the back of the bell housing near the starter...
Turbo bad...may be leaking oil.
The clutch master and or the clutch slave cylinders may be leaking, bleed the clutch and see what happens.
The clutch peddle has a spring to assist the driver in pushing down the peddle. _________________ White 87 924S "Ghost"
johnathan1
Posted: Sun Oct 28, 2007 2:46 pm Post subject: |
Not sure about the oil leak...
But for the clutch...check to make sure the fluid isn't low...probably a leaking master/slave. _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
Posted: Sun Oct 28, 2007 3:10 pm Post subject: |
| You need to change both the slave and the master clutch cylinders. When one is dead, the other is dying. |
924guy
Posted: Sun Oct 28, 2007 9:49 pm Post subject: |
try bleeding the slave cylinder before you go nuts on replacing everything. it has a bleed fitting right on it.. in my experience the slave fails twice as often as the master, generally due to rebuilt s being installed.
as for the oil leak, in that area you have several pipe connections, i would first check the oil cooler lines, and above that where there are several potential oil leak spots, and try and locate the exact source of the leak before starting a turbo rebuild. even if your turbo is bad, you could have another issue that contributed to failure like an oil leak to a feed line or oil cooler line, and should correct that prior to replacing the turbo, or during the turbo r&r so it doesn't happen again. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sun Oct 28, 2007 10:27 pm Post subject: |
And don't forget to change the timing belt first, since the 931 is an interference engine like the 944 and 924S.
You don't want ad to your problems by bending the valves. |
skytrooper
Posted: Mon Oct 29, 2007 1:27 am Post subject: |
| gohim wrote: | And don't forget to change the timing belt first, since the 931 is an interference engine like the 944 and 924S.
Yep, thats going to be part of the rebuild. BTW my 924S goes in to get its front of engine service on the 5th. A well known and respected european repair shop is doing the whole shebang for $1100.00. The 931 I am going to tackle myself.
I gotta get a manual for the 931 now, so I can start getting my hands dirty |
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Mon Oct 29, 2007 4:49 am Post subject: |
The reason the slaves fail more often than master is the slave is the lowest point in the hydraulic clutch and brake system and water pools there.
The slave and master bodies are cast metal and very cheap. They rust and pit out very easily.
There is no rebuilt for the slave. At one time you could buy a 928 rebuild kit, news seals and spring.
The best long term approach is to always do the 2 year fluid change especially for the clutch.
The oil pooling under the turbo is more than likely a bad o-ring seal on the bottom return line. 2 13 mm bolts hold it on., the o-ring is a porsche part unless you know where to source high heat nitrile o-rings You can easily inspect that for proof of oil leak.
Before assuming the turbo is locked up you need to rev the engine listen for turbo whine check and also for any vacuum line leakage and including the bypass line control. Buy a cheap boost gauge and T it into one of the vacuum lines. Rev the engine and see if you see a bump in manifold pressure. Also listen for turbo whine (spooling). Sometime the wastegate can get stuck open.
If you are really handy and feel like you can get to the 10 mm bolts on the housing you can remove the front of the turbo while it is on the car. It is tough and sometimes impossible to reach each bolt. But the housing will rotate.
If they had reversed the bolt to the outside it would be so much nicer.
You can take the housing off and check your turbo for spinning by hand and check for axial play. _________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
Posted: Mon Oct 29, 2007 3:06 pm Post subject: |
Whoops - the clutch slave seal kit is still available. I've been getting them from partsamerica.com the last few times. They have them at about $15. Just rebuilt one and popped it in today in fact - that and my once-a-year starter solenoid cleaning got done.
http://www.partsamerica.com/productdetail.aspx?MfrCode=TRQ&MfrPartNumber=CSK103545&PartType=237&PTSet=A _________________ "..it's made in Germany. You know the Germans always make good stuff."
Zuffen
Posted: Mon Oct 29, 2007 3:44 pm Post subject: |
they were twice that from porsche, when they made them. we never rebuilt them...I have box of them somewhere as I never tossed them. I planed to sleeve them with brass and make them last longer. _________________ Bob Dodd - 924turbo@cox.net
skytrooper
Posted: Tue Oct 30, 2007 8:40 am Post subject: |
Yup, slave cylinder was messed up pretty bad. So much fluid going through the seal that it was dripping out of the starter flange drain hole.
The bore looks great though so I will get a rebuild kit. _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
Posted: Tue Oct 30, 2007 9:37 am Post subject: |
Here's what I do at this point to make life easier and simplify the bleed process..
Cap the line where it attaches to the slave until you're ready to reinstall the rebuilt part. Empty the brake fluid reservoir (or the seperate clutch fluid reservoir for anyone with a RHD car). I use a Mityvac and a seperate container for this - a line sealed to the container lid has its' other end placed in the brake fluid reservoir, and the mityvac is attached to another hole in the containers' lid and used to draw a vacuum on it. _This pulls the brake fluid into the container without drawing it into the mityvac.
Refill the reservoir with fresh fluid and cap it.
Once the slave cyl is rebuilt, bench bleed it to fill it with brake fluid and expel all air bubbles. Use the cap from a transmission oil bottle as a small funnel, cut off to fit and screw into the slaves' line attachment port.
Get the line attachment threaded on and just slightly tightened - so it can be swiveled some. Position the slaves' rod into the end of the clutch fork and push it in, and attach and tighten the 2 slave mounting bolts. (As the slave is pushed into position, the rod is pushed in, and that pushes fluid from the slave up the line, removing most of the air.) Give the line attachment a final tightening. Check the fluid level.
Then just pump the clutch pedal by hand quickly until you feel it start to develop some resistance. At that point, continue pumping, but now pump it only a bit into the resistance instead of all the way to the floor. When the pedal starts to return on its' own, get in and pump it by foot another 10 or so times and you're done - no need to crawl under to bleed it in the usual way. _________________ "..it's made in Germany. You know the Germans always make good stuff."
skytrooper
Posted: Tue Oct 30, 2007 10:03 am Post subject: |
Thanks Smoothie, That should save me a lot of time !
>S< _________________ Matt
1982 - BMW 633CSi
1984 - BMW 528e
