control arm bushings
B
PostPosted: Mon Oct 29, 2007 1:53 am    Post subject: control arm bushings Reply with quote
I found some bushings for the control arm on ebay I wondered if these looked like the correct ones to anyone who has purchased a set. They say they are but I haven't looked much for these but I will need to this winter. So any input would be greatly appreciated. they are on ebay item # 250178677726 http://cgi.ebay.com/ebaymotors/PORSCHE-924-control-arm-bushings-energy-suspension[url]
(I hope that's right)
thanks
B[/url]
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Mon Oct 29, 2007 2:15 am    Post subject: Reply with quote
I just bought a set for Red for $22 brand new at my local German speed shop. The brand was Prothane, and the parts were labeled as for "VW Golf/Rabbit I," meaning the first generation Rabbit.
Their website lists 4 locations in Ohio as vendors. I just looked at one of them, who also carry Energy for a price similar to that auction. The key is to get "Rabbit" instead of "Porsche."
rasta
B
PostPosted: Mon Oct 29, 2007 5:24 am    Post subject: Reply with quote
Rasta
do you know if those are the same for a '79 n/a?
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Mon Oct 29, 2007 5:53 am    Post subject: Reply with quote
Yeah dude, why else would I recommend? The control arms were sourced from the VW/Audi parts bin, and were also used on Wabbit Mark I (75-84).
Be prepared to run them to a machine shop for removal of the old ones. It is a major PITA. Also worthwhile to seam weld them, and have them powder coated while they are off.
B
PostPosted: Mon Oct 29, 2007 10:44 am    Post subject: Reply with quote
Sorry Rasta, my brains not working too well today(?)
you need a press for the new ones right?
what will you need to seem weld?
Thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Mon Oct 29, 2007 11:44 am    Post subject: Reply with quote
No press for the new ones. They slip in, but I did use a C-clamp to install the metal sleeve in the fronts.
Seam welding just runs a bead along the joint between the two pressed halves of the control arm (upper & lower) for added strength. Not sure if it is critical, but was recommended here, and should be cheap.
