t bars
jesse wall
PostPosted: Fri Nov 16, 2007 12:46 am    Post subject: t bars Reply with quote
If you want to change your torsion bars or change ride height in rear check out this month's 9 magazine on line Jesse
jesse wall 'new driver' , 87 924s
Dutch924-racer
PostPosted: Fri Nov 16, 2007 6:34 am    Post subject: Reply with quote
Do you have an link ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
jesse wall
PostPosted: Fri Nov 16, 2007 11:59 am    Post subject: t bars Reply with quote
Just go to 9magazine.com the new issue is the one with the porsche designed boat on the cover , if you need any help just let me know , will take about 1 to 2 hr first time and about 15 min per side after that to change height or bars , easy Jesse
joecitizennn
PostPosted: Fri Nov 16, 2007 12:26 pm    Post subject: Reply with quote
http://9magazine.com/files/issue30.2.pdf
Sheesh, they made a big ass hole in that fender.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Rich H
PostPosted: Fri Nov 16, 2007 6:02 pm    Post subject: Reply with quote
Would it not be easier just to drop the suspension?
When I changed the torque tube (Pilot bearing failed and ate my propshaft) the whole rear suspension came out without too much of a fight.
Looks a damn sight easier than tapping a super hard torsion bar and cutting the bodywork!
PostPosted: Fri Nov 16, 2007 8:40 pm    Post subject: Reply with quote
Why drilling holes ? My 4/1977 NA 924 has the original holes,like the 911...
Rich H
PostPosted: Fri Nov 16, 2007 10:18 pm    Post subject: Reply with quote
Later cars don't have holes at all.
jesse wall
PostPosted: Sat Nov 17, 2007 1:18 am    Post subject: t bars Reply with quote
well takes about 15 minutes to drill and tap the one t bar , the orginal early cars had the holes in rocker panel , once the first t bar change is done you can change ride height in a few minutes you can also change the spring rate at will ,at the track if you so desire , for those who are going to delron bushings it is still very nice to be able to make adjustments this way . With the delron bushings in the carrieer it is even easier ,Lawerance changed his ride height 3 times in 15 minutes by himself I was in shop doing something else. Of course this was on race car that had everything new , bolts nuts etc, no rust , Our first experience in removing entire rear suspensionwas on 924 s from west va salted very well , and this involved a lot of rust remover and a very large compressor with air gun , and took us forever and ever. This is just a simple way for your track or street track car to have nice spring rate in rear , you can borrow some tbars and try them out , . Another point is that a friend is front runner in 944 cup is still driving stock rear bushings now that he is hoping to finish first next year instead of second overall for the season; he is going to the hard bushings until you need the tenths of seconds the stock bushings will do well , on a street or street track car they give a much better ride
Dutch924-racer
PostPosted: Mon Nov 19, 2007 6:14 am    Post subject: Reply with quote
Nobbi or anybody else with an early 924
Do you have a pictures of the original tbar hole in your car ?
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Mon Nov 19, 2007 7:53 am    Post subject: Reply with quote
WTF are "accoulaides?"
jesse wall
PostPosted: Mon Nov 19, 2007 8:49 am    Post subject: w.. Reply with quote
well I think they are what happens when the wrong keys are struck.
