NorthPorsche
Posted: Thu Nov 22, 2007 2:36 pm Post subject: anyone know were to got adaptor for fuel pump |
I still working on geting the 924 runing fuel pump is dead I have a pump out of a 88scrocco 16v its same size has same inlet size termials easylly changed but the one way valve that screws in the end is the wrong size ( its the newer size biger) so I need a adaptor tha has big male into pump and small female for my odl one to go into then I can put line etc the Pierburg fuel pump replacmet seams to come with this adaptor ( I think its one of the adaptors in the pic) any help would be apreatiated , thanks Nat _________________ I reject your reality and subsitute my own ... |
D Hook
Posted: Thu Nov 22, 2007 10:36 pm Post subject: |
Do you know if the pressure matches on the Sirroco pump to what the 924 needs?
You should be able to find the adapters at most hardward stores in the metric section of steel adapters. _________________ '80 924 n/a SOLD |
