Blas
Joined: 05 Nov 2002 Posts: 227 Location: Illinois, USA
Posted: Sun Sep 10, 2006 9:41 am Post subject: Spark Plugs: Bosh Platinums or Splitfires? |
Doing a little tune-up work and I found a set of Bosh Platinums and a set of Splitfires in my parts boxes. Any pros or cons with either brand? What would be the proper gap for each set? The Bosch says .028 on the box the Splitfires say nothing. My 924 maunal says .024 for regular Bosh or Champion plugs....
As usual, thanks everyone.... |
Diesel
Posted: Sun Sep 10, 2006 10:52 am Post subject: |
Those 2 plugs are the absolute worst choices. Go for the regular Bosch plugs, they are more than adequate. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
Blas
Posted: Sun Sep 10, 2006 11:12 am Post subject: |
Can you expound on those comments a bit please?
Thanks |
D Hook
Posted: Sun Sep 10, 2006 1:57 pm Post subject: |
I tried the splitfires when they first came out. Didn't notice any difference.
Since then, they've been forced to back off some of their claims about improved gas mileage and performance. Also have been stories about one of the nodes breaking off and ruining the side of the cylinder walls and how the spark has a tendency to jump only to the same node after awhile, making them just an expensive single node plug.
Most information I've read about them says they're not worth the extra money. But it's your money.
I've used champions before but not in my 924. No complaints.
Why not go with the Bosch platinums? _________________ '80 924 n/a SOLD |
endwrench
Posted: Sun Sep 10, 2006 2:03 pm Post subject: |
I have to agree with Diesel. I have had nothing but problems with the Bosch Platinum plugs. I have tried them several times in a variety of customers cars and I hate them!! They missfire, don't fire or just idle like crap. The splitfires don't seem to be any better than standard plugs. They just don't live up to the hype. I'd run them before the Platinums though. If you want a good long lasting workhorse of a plug, go with the standard Bosche plug. If you want a little more refined better idleing but short lved plug, go with standard NGK's. JMTC
augidog
Posted: Sun Sep 10, 2006 10:58 pm Post subject: |
| endwrench wrote: | I have to agree with Diesel. I have had nothing but problems with the Bosch Platinum plugs. They missfire, don't fire or just idle like crap.
Todd |
Same results here on my NA.
Put the magic bean spitfires in since you have them.
Go with Bosch copper; or I just found some OEM Bosch silver plugs and they seem to work well so far. _________________ 1978 924 95 mile daily driver.
Diesel
Posted: Mon Sep 11, 2006 10:12 am Post subject: |
It's common knowledge among professional mechanics that Bosch Platinums misfire. They should be banned by the EPA they destroy so many catalytic converters. As far as Splitfires, when they first came out I saw one spit the porcelain portion right out of the head, leaving the threaded part in place. Some quality there. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
Posted: Mon Sep 11, 2006 10:41 am Post subject: |
I use Autolite plugs in my 931 after trying many others. My second choice is Champions.
I too tried the plats, my 931 would not even idle. _________________ White 87 924S "Ghost"
koolkarateguy
Joined: 16 Dec 2005 Posts: 108 Location: Nova Scotia ,Canada
Posted: Mon Sep 11, 2006 11:25 am Post subject: |
I put NGK Silver in mine back in March, they've worked very well and are still pretty clean. _________________ 1979 N/A 924 |
dpw928
Posted: Mon Sep 11, 2006 11:59 am Post subject: |
I used to use NGK's until I changed them out on my wifes SUV. All of them had been leaking between the metal and ceramic. Now I'm back to Autolite and Champion.
78 928 5 sp Silver
78 928 AT Euro Black |
moone924
Joined: 05 Feb 2003 Posts: 869 Location: Douglas Wyoming
Posted: Mon Sep 11, 2006 12:25 pm Post subject: |
I use the Bosch W7DTC Tri-Electrode (copper) on my 924 and Audis. _________________ Ryan Moone
New philosophy : one car project at a time. |
Chrenan
Posted: Wed Sep 13, 2006 8:07 am Post subject: |
Based on this topic I swapped out my Bosch platinums for a set of Champion coppers today. It does seem smoother with the coppers, might be psychological, or maybe the Bosch platinums really do misfire, I had never heard of this problem before. _________________ 1987 951 - M193 Version for Japan |
Stampedetrail
Posted: Thu Sep 14, 2006 2:42 pm Post subject: |
Slightly hotter than stock NGKs is what I've been running, because of all the sloppy oil control. They burn that stuff right up. Starts better cold with them than with stock Bosch or Autolite plugs. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Blas
Posted: Wed Sep 20, 2006 12:33 am Post subject: |
| I had BOSCH WR7DP plugs on the car and I swapped them out to NGK #BP7ES... apperars to idle smoother now. |
Posted: Wed Sep 20, 2006 3:38 am Post subject: |
I ran platniums in the 78 I had and it ran ok for 2 months then got high speed glazing on it and wouldnt run at all,
I have tried the NGK Iridium ones they lasted abit longer, but the hottest spark I coud ever get was from bosch coppers. _________________ 3 928s, |
