let me ask the question in a different way
chrisoc
Guest
PostPosted: Fri Apr 05, 2002 2:18 am    Post subject: Reply with quote
Will a stock clutch kit from a 951 bolt to a stock manual transmission from a 924S?
Is it a simple swap or do modifications or other parts need to be on hand to make it work?
I have to have some work done on the transmission anyway so I thought I would see if that was a viable option. Any help would be greatly appreciated.
-nick
Guest
PostPosted: Fri Apr 05, 2002 4:49 am    Post subject: Reply with quote
the 951 clutch disk is much bigger. at the very least you would need the turbo flywheel. why would you want to do this? is yours slipping under power?
-nick
chrisoc
Guest
PostPosted: Fri Apr 05, 2002 8:03 am    Post subject: Reply with quote
Not yet but I get a slight hesitation and the a solid hook up when up shifting. As if the rubber center is flexing or something.
-nick
Guest
PostPosted: Fri Apr 05, 2002 8:11 am    Post subject: Reply with quote
ahh, yeah i just read your other post. i forgot about the rubber vs. spring centers.
i wouldn't wish a clutch job on my worst enemy. my back hurts just thinking about it.
-nick
