Why is my S so jerky???
Johnny_924S
Guest
PostPosted: Fri Feb 08, 2002 2:01 pm    Post subject: Reply with quote
Hey people, i just wanted to know if anyone elso out there who drives an 87 924S has noticed that when in the lower gears...i.e. first, second, the throttle is EXTREAMLY jerky, If you go on and off the gas quick it almost feels as if the body is going to fly ff the wheels??? i just rebuilt the top end and and was told that this could be due to high compression but dam its a rough ride. anyway, if you have any ideas, please let me know. thanks, johnny
Zuffen
PostPosted: Sat Feb 09, 2002 2:23 am    Post subject: Reply with quote
Sure it ain't the driver!
LOL
I've had that problem on a 931 hitting rough spots in the road at low speed.
My case would be the flapper bouncing, but yours has the flapper in a differnt direction, could be doing the same thing.
Might check your throttle linkage , it may be too tight hence to sensitive. It is hard to keep the foot steady when bouncing around.
Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951
wdb
Guest
PostPosted: Sat Feb 09, 2002 8:52 am    Post subject: Reply with quote
if there is air in the brake lines,your brakes will drag,slowing you as soon as you lift your fooy off the gas
Johnny_924S
Guest
PostPosted: Sun Feb 10, 2002 9:33 am    Post subject: Reply with quote
thanks, i just replaced my slave cylinder and there could be air in there, i also just replaced my brake light switch so that may be the culprit...ill let you know how it went, thanks, johnny
ps, i know for dam sure it aint the driver....its me..ha ha thanks
yOnKiNaToR
Guest
PostPosted: Mon Apr 08, 2002 9:11 am    Post subject: Reply with quote
i have heard that it could be the rubber thing on the clutch that has gone bad...my car jerks too, regardless of how gentle i am on the gas. the mechanic told me the clutch felt "tight." i also have to bleed my clutch..could that have anything to do with it to?
