Weird Aux Fan
dash16
PostPosted: Wed Mar 12, 2008 9:51 pm    Post subject: Weird Aux Fan Reply with quote
My aux fan usually has to be trigger by my turning on the AC when idling in traffic because it will not flip on by itself.
While returning to my car one freezing night, i drove my car home and the fan turned on by itself.
When I returned home, i was surprised to find that the fan remained running after I had switch the car off.
I figured it would be fine. I returned to my car 10 minutes later, the fan was still running. It could not have possibly have been triggered from heat since it was freezing cold out.
I unhook and hook the battery and the fan did not re-trigger.
What could have possibly happenned? Electrical bug?
Is there a way to run an electrical diagnostic on my car?
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
bcblase
PostPosted: Wed Mar 12, 2008 11:31 pm    Post subject: Reply with quote
Sounds like you need to replace the fan temp. switch located on the top left side of the radiator. My fan turns on a bit early, because I think it was replaced with a lower temp switch. I have the new switch with a higher temp rating, but I have not had a chance to install it yet.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
PostPosted: Thu Mar 13, 2008 1:51 am    Post subject: Reply with quote
Red did this. . .fans ran the battery down because the relay was bad.
If you swap the relay, inspect the fan wiring harness. A short there is what actually messed the relay up in Red's case.
joecitizennn
PostPosted: Thu Mar 13, 2008 6:48 am    Post subject: Reply with quote
The next time you shut off the car and the fan is running, reach down behind the drivers headlight pull one of the wires out of the thermofan switch to see if the fans shut off. They should
Next unplug both wires and put a jumper between them to see if the fans come on when the wires connect and shut off when the wires disconnect. If this is the case the wiring is ok and the problem in in the switch.
Oh yeah, you may have to remove the airbox to be able to plug them back in. Dont say I didnt warn you.
