Distributor/fuel relay
Dan
PostPosted: Mon Apr 28, 2008 12:31 am    Post subject: Distributor/fuel relay Reply with quote
Is that the timing mark on the distributor?
Also just replaced fuel pump relay, I cant turn the engine over (Cams off) but when the ignition is put to on position, I get voltage at the pump for about a second, not long enough to get a good reading.
I understand this is to pressure up but I don't hear the pump run (the pump works wired direct)
How long is normal when initially energised should this relay stay on to pressurise, as my replacement has four spades , and the old one (smells burnt) has an extra miniture spade, so I'm not sure its the right one?
Will the pump run if already at pressure?
Is there any way to test without turning the motor over?
Dan
1979/924 N/A
Street Racer KTA508V
©2008
PostPosted: Mon Apr 28, 2008 1:40 am    Post subject: Reply with quote
Yes, the rotor should point at that mark when #1 is at TDC. This sets the timing near TDC, then use a timing light.
Jumper the fuel pump relay to see if the pump and wiring are OK.
PostPosted: Mon Apr 28, 2008 7:29 am    Post subject: Reply with quote
On later cars the pump only runs when cranking or engine is running.
Not sure when it changed from a switch on the CIS.
PostPosted: Mon Apr 28, 2008 5:31 pm    Post subject: Reply with quote
The fuel pump relay behaviour that you describe is correct for the later type of relay. Don't be concerned that you can't hear the pump during that first second.
The miniature spade gets a signal from the coil when the engine is running. If the engine stalls, the relay cuts power to the pump. It's a safety feature in case of an accident, etc.
Earlier cars only had a four-terminal fuel pump relay. The cut out feature was a switch on the air meter. I think by 1979 all cars had the later relay, but I can't be sure...
