radio turns on when key is put in ignition
thirdgenbird
PostPosted: Wed May 21, 2008 11:23 am    Post subject: radio turns on when key is put in ignition Reply with quote
i bought my 87 924s with an aftermarket tape player that comes on when the key is placed in the ignition. was this wired incorectly or is this normal for these cars?
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
PostPosted: Wed May 21, 2008 11:39 am    Post subject: Reply with quote
It's normal. Key in without turning either way enables power for the sound system.
thirdgenbird
PostPosted: Wed May 21, 2008 11:41 am    Post subject: Reply with quote
thank you, the last thing i need is an electrical problem.
bcblase
PostPosted: Wed May 21, 2008 1:11 pm    Post subject: Reply with quote
Is there any way to keep power to the stereo so I don't lose all my settings everytime I turn the car off? I thought the fat red wire was supposed to be the non-switched power feed.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
v8carreragts
PostPosted: Thu May 22, 2008 12:31 am    Post subject: Reply with quote
there should be two power wires. One is B+ (battery) for the memory and the other is switched for the radio function and power section. If it is a factory radio you may have a bad connection or cut wire.
If it is an aftermarket radio it was probably wired wrong. usually aftermarket radios have the wiring diagram attached to the body of the radio. Usually the radio will not turn on without the memory wire connected so there should be two wires connected to power then. If you take one and connect it to B+ and the radio does not turn on then you need to swap them.
Martijnus
PostPosted: Thu May 22, 2008 3:02 am    Post subject: Reply with quote
for just a minute you got me scared when I read the title...
I always thought it was convenient and normal, but now I thought it could be a malfunction but it isn't
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
v8carreragts
PostPosted: Fri May 23, 2008 5:59 am    Post subject: Reply with quote
There is a switch in the ignition lock mechinism that is used for the radio. That is normal.
Loosing the memory when you turn off the car isn't.
