77 924 IS'NT STARTING
Goto page 1, 2, 3  Next
old 924
PostPosted: Tue Mar 13, 2012 2:22 pm    Post subject: 77 924 IS'NT STARTING Reply with quote
i've had the car for 4or5 week's now..it ran when i got it..i towed it home and started sanding it down for a respray. and didnt start it again .any way i went out to day to start it and it wont fire up..got new batt.. i put in new plugs wires cap and roter..has gas and spark..it wonts to start but wont..does any one have any clues that can help..and the bad thing is that im going to have to start driveing this cuz my ex just got my other car...i would love any help...thank's
base 77 924 2.0 (may the porsche be with you)
PostPosted: Tue Mar 13, 2012 3:16 pm    Post subject: Reply with quote
can you here the fuel pump buzz in the back when you turn the key to on ?? if not its probly a fuel pump relay.
old 924
PostPosted: Tue Mar 13, 2012 3:26 pm    Post subject: Reply with quote
I TOOK THE LINE OFF THE FILTER AND TUNED THE KEY FOR A SEC. AND GAS CAME OUT...BUT NO I DONT HEAR THE PUMP OR RELAY FROM IN THE CAR..??..
musicalannette
PostPosted: Tue Mar 13, 2012 3:31 pm    Post subject: Reply with quote
If fuel comes out then your probably good for fuel being ok. As you have a spark there and you have changed the distributor cap, the rotor arm and plug leads, I would double check the leads are on in the right places at the cap and plugs.
Hope this helps.
old 924
PostPosted: Tue Mar 13, 2012 3:55 pm    Post subject: Reply with quote
Hope this helps.
i changed every thing after it wouldnt start..every thing is on the way it should..could the coil be weak..??cold start valve..?? i mean it didnt run great when i got it but it did run..i was just going to do the tune up stuff when i was going to start driveing it..thats why i already had the tune up parts..i spent a good part or the day inbetween rain storms working on it..
staticsan
PostPosted: Tue Mar 13, 2012 6:18 pm    Post subject: Reply with quote
Assuming it turns over, does it catch at all? Or is there just the sound of the starter? What if you open the throttle slightly (simulates cold AAV)? Does that make a difference?
Have you checked the intake boots are all snug and all hoses sound? The CIS in the 924 really doesn't like vacuum leaks.
Wade.
old 924
PostPosted: Tue Mar 13, 2012 6:42 pm    Post subject: Reply with quote
Wade.
i tryed to find a leak in the vac..didnt see any..not saying there not there thow..im going at it again in the morning..i was reading my book and was thinking maybe it could be the transistorized ignition unit..???..i think i have a spear that came with the car.ill have to look..?? sh*t am even going to recheack the fireing order..i dont see why its not starting..and yes its catching just dosent want to come to life..??
musicalannette
PostPosted: Tue Mar 13, 2012 10:53 pm    Post subject: Reply with quote
Hi,
the fact it's catching means your really close, I doubt it is the ignition box, if it is giving you a spark I doubt very much something has gone in there that will give you a spark that is weak, no spark, yes it could be that, but with a spark, I doubt it, very, very low probability. If the ignition module has gone there will (99 times out of 100) be no spark. Most probably if the spark is weak (and with new spark plugs, the spark should be blue-ish in colour not yellow, if it#s yellow then it probably is weak) then I would suggest the coil is to blame. If you had it so it's nearly firing, then I would double check the ignition timing with a strobe. I also doubt the fuel system has changed, but if it's been standing, it might take 10 or 15 seconds cranking to get the fuel system happy.
I'm not saying you have screwed up the plug lead order, but if two leads are crossed, then the thing will probably almost fire being a four cylinder, you might even just get it to run (although it will be very rough). I know on here, quite a few people seem to have problems with cold start, I have not had any problems myself so I have not looked into it, and it would be very unlucky for it to go while your spraying, but maybee there is a test you can do to check this and eliminate it from list of possible problems.
Stick with it, i'm sure it will get sorted with a bit of help from these guys.
hope this helps.
DOCO
PostPosted: Tue Mar 13, 2012 11:24 pm    Post subject: Reply with quote
Hi hold your foot to floor while cranking...did it start or sound better than it did?no change?loosen the distributor bolt a bit so you can turn dist.try starting again?start?yay !!!no ooooo? pull a spark plug is it wet with fuel?or dry as a popcorn fart?check and make sure you have spark at the spark plug...wet its flooding and youll have to get into the fuel delivery system.cant help you there.dry try putting some fuel into the cylinders directly.sounds really like its flooded or the timing of dist.is just out a bit.just a few more places to look.hope this helps.
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
old 924
PostPosted: Wed Mar 14, 2012 5:09 am    Post subject: Reply with quote
IT STARTED FOR LIKE 2 SEC.. AND NOTHING AGAIN..im getting so mad im finding other things to fix..i just changed my headlight motor and relay and the dame plug..well now my headlights work the way they should now..lol..i had to walk away from the not starting thing for a min...ive got tons of spear parts that came with the car..if i have to ill change every dame one of them..lol..but still no real start..could the air timer thing be bad..??
musicalannette
PostPosted: Wed Mar 14, 2012 5:29 am    Post subject: Reply with quote
Hi, buddy,
Not sure what an air timer is??
the fact it ran for a couple of secs means timing is close if not perfect and theres fuel there, how good is your battery? will it turn the car over for a minute before it goes flat? just thinking, if it marginal you might want to charge it, that would help.
keep at it
old 924
PostPosted: Wed Mar 14, 2012 5:53 am    Post subject: Reply with quote
Hi, buddy,
keep at it
JUST GOT A BATT. YESTERDAY WHEN I STARTED ALL THIS .. here is what i found...that some retart did....ther is something on the head on the back of the motor below the dist.. it has two wire's that come out..there both cut..some one ran jumpers from there to were the wire's were cut next to the dist. one wire is off on that unit and its the red wire and i cant seem to get to it..would that keep it from starting..??im looking in my book and i cant find what ti is..
old 924
PostPosted: Wed Mar 14, 2012 7:35 am    Post subject: Reply with quote
I FEEL LIKE IM WORKING ON A U.S. CAR..IM FROM THE U.S BUT IVE MOSTLY HAD BMW'S (E30'S) AND MGB'S..BUT NO ....I HAD TO HAVE A 924..SOME ONE SHOOT ME..LOL..
PostPosted: Wed Mar 14, 2012 7:55 am    Post subject: Reply with quote
There is a procedure for testing a no-start condition systematically. Check your PM's.
PostPosted: Wed Mar 14, 2012 7:59 am    Post subject: Reply with quote
Those wires could be for the CSV, WUR or AAV.
all require power for starting and running.
Temp and oil senders are under the distributor too.
Page 1 of 3
