Posted: Tue Dec 07, 2004 6:57 am Post subject: Fuel Meter Reading - when it feels like it! |
I have a problem with my fuel meter.
It reads just under 1/4 of a tank when, in fact, the tank is EMPTY!
I got caught out the other night. Luckily, it was just yards from my home (on the way there, not out!)
I've had a look at the sender and I think it's working correctly. The problem is that when the float hits the fuel light contacts, it can't go down any further, so the meter reading stays stuck at that level.
(Why didn't I see the fuel warning light? Because the contacts were covered with a coating of fine powdery rust. They're clean now, so at least the light comes on.)
I've measured the resistance of the sender with the float at the bottom and got a reading of about 75 ohms, but the meter still reads about 1/4. It seems to me that when the float is at the bottom, you want the meter needle to sit on the red 'R' mark, but I think you'd need over 100 ohms to get this.
OK, so I tried a different sender unit. It was WORSE! The meter reads OVER 1/4 full.
Is there some adjustment at the meter end? Or am I missing something? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue Dec 07, 2004 9:28 am Post subject: |
| Check both ends of the ground connection for the sender unit, or temporary run a new one to see if it makes a difference. |
Posted: Wed Dec 08, 2004 2:35 am Post subject: |
| Paul wrote: | | Check both ends of the ground connection for the sender unit, or temporary run a new one to see if it makes a difference. |
Good thought, Paul, but I think I've got the opposite problem. A bad earth (or is it ground?) would increase the resistance the meter sees and make it read too low. Mine reads too high!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Tiny
Posted: Sat Jul 26, 2008 11:17 pm Post subject: |
Have exactly the same problem as mike here. Checked the resistance levels as per haynes and the senders i have are within range.
But here's what happens
With the float at the bottom, and the light on. The guage still reads between 1/4 and 1/2 full.
When I invert the the sender (turn it upside down). I can see the light switch off, and the when the guage needle rises with the float to full.
This is same problem with the other 2 senders I have.
I have just cleaned and tested the grounds on the car. took a while.
2 crowns under dash.
1 crown behind fuel gauge
1 point between rear lights.
2 points near headlights
I have run a new ground direct to the sender, and checked the quality with an ohm meter. No difference overall though
I have traced the senders signal to E12 and F12 on the back of the relay panel, and cleaned those connections up. No change.
The senders signal also goes through pin 8 and pin 9 on the dash gauge's connector...so im gonna have a look at the connections to that pin and clean them up and tighten the connectors.
All I can think is that over time the resistance of the sender has changed and now no logner allows the correct amount which would let the fuel gauge needle drop down below the 1/4 mark.
any other ideas guys?
tiny _________________ *****1981 - 924 - Auto - London, UK****** |
D Hook
Posted: Mon Jul 28, 2008 12:31 am Post subject: |
Unplugging and replugging the plug behind the gauge (big round white one) a few times helped all my guages in that cluster. Temp gauge, too. _________________ '80 924 n/a SOLD |
Posted: Mon Jul 28, 2008 5:47 pm Post subject: |
^ +1
Didn't completely cure the problem, but it did help.
I've just learned to live with it now. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Tiny
Posted: Mon Jul 28, 2008 9:41 pm Post subject: |
Well, I cleaned up all the pins and connections on the multi-round connector behind the dash...and replaced the fuse/relay board just for the heck of it...and on an empty tank..the lowest the needle will go is a 1/4.
looks like i'll have to live with mystery of my fuel level...until the light comes on... too.
i might get another fuel guage, and see what that does.
or perhaps...ill once again.... fix that little gear that slips... in the mileometer so i can calculate my fuel in my head.
thanks guys
Rich H
Posted: Mon Jul 28, 2008 9:53 pm Post subject: |
could the light coming on be interfering with the output of the sender? They use the same earth so a trickle of current through the light might be fooling the meter? _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Jul 30, 2008 3:13 am Post subject: |
Good thinking, Rich, but I don't think that's it.
The needle seems to bottom out at about 1/4 full (or just above the 'R' mark now that I've cleaned the rear contacts), sit there for several miles and then the light comes on...
Ho-hum.  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Vince Ponz
Posted: Wed Jul 30, 2008 3:43 am Post subject: |
The fix for the speedo is easy. The cost of the gear is anywhere from 20 to 30 dollars.
You can try to epoxy it if and when you remove the speedo. I did it and it lasted for a couple of years.
Need help ask me. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
