Thruxton900
Joined: 05 May 2008 Posts: 51 Location: Adelaide, South Australia
Posted: Sun Aug 17, 2008 3:28 pm Post subject: Crankcase breather - great result |
I have a small oil leak from the dipstick , so I flushed the breather with degreaser. I guess its now unclogged
because it now blows out air??
Ive also disconnected the other hose to the charcoal canister
Question - Should the crankcase breather be blowing out or sucking in air?
thanks _________________ 1977 NA 924 sold in 2008.
1967 Porsche 912
Last edited by Thruxton900 on Tue Aug 19, 2008 12:12 am; edited 5 times in total |
Posted: Sun Aug 17, 2008 3:29 pm Post subject: |
Charcoal canister?
Is yours an oz car or an import?
The crankcase will blow out air. _________________ Porsche 924 1984 (UK import) NA
Thruxton900
Posted: Sun Aug 17, 2008 4:02 pm Post subject: |
thanks ozzie
Mine has a canister in the passenger side front wheel arch.
My 924 has service history going back to 1977 and documentation that is was bought in Sydney, therefore assume
its an Australian delivered.
Does the canister suggest otherwise? _________________ 1977 NA 924 sold in 2008.
1967 Porsche 912 |
Posted: Sun Aug 17, 2008 4:32 pm Post subject: |
Not really- havent seen an early model.
Mine doesnt have one but its a UK import _________________ Porsche 924 1984 (UK import) NA
Thruxton900
Posted: Sun Aug 17, 2008 8:25 pm Post subject: |
Took it for a spin and got an immediate increase in responsiveness. Not just a little...quite a bit!!
And....now my tacho works properly...( needle now goes beyond 3000).
And this from only just a few squirts of degreaser( and left overnight) into the crankcase breather
explanation...?
what does the tacho run off? _________________ 1977 NA 924 sold in 2008.
1967 Porsche 912
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Sun Aug 17, 2008 8:56 pm Post subject: |
| Ozzie wrote: | Charcoal canister?
The crankcase will blow out air. |
I have one in mine too. Oz delivered.
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Sun Aug 17, 2008 10:09 pm Post subject: |
Ozzie,
I'm surprised that they allowed your car to be registered in Aus without a charcoal canister. ADR27A which became law in mid-1976 was the emissions ADR and required all cars after that date to have a canister. Perhaps emissions are like red lights in the Sunshine State - optional  _________________ 1979 924 (Gone to a better place)
Posted: Sun Aug 17, 2008 10:33 pm Post subject: |
| Thruxton900 wrote: |
what does the tacho run off? |
Pretty sure you'll find it doesn't run off the crankcase breather...!! I think you've hit upon one of the wonders of working on old cars - "stuff happens"
69 911 |
Posted: Mon Aug 18, 2008 12:25 am Post subject: |
Did you name your car " christine".......?  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
RC
Posted: Mon Aug 18, 2008 12:26 am Post subject: |
Mine HAD a canister in LH wheel arch originally too. Thought they were fitted to all Au cars, early and late. Qld and SA don`t have any annual inspection like NSW or Vic.
The breather should not be blowing out much air at all if the piston rings are good. Air? coming out indicates leakage (blow by) of the rings.
The tacho runs from ignition pulses from the coil - via a green wire. Direct from the coil on points dizzys or the TIU connection that also connects to the coil - on VR (later) dizzy. Wires run along firewall behind the breather so you most likely inadvertently bridged a poor connection or broken wire. Gotta have some luck sometimes. So if it starts playing up again you know where to look first. Or maybe it never revved past 3K with a choked breather.  |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Mon Aug 18, 2008 3:20 am Post subject: Re: Crankcase breather - great results now! |
| Thruxton900 wrote: | I have a small oil leak from the dipstick , so I flushed the breather with degreaser. I guess its now unclogged
because it now blows out air?? |
Can you outline the procedure you used as I was thinking about doing mine the difficult way but I may try this first.
Thanks _________________ 1977 924 2.0 Auto |
Martijnus
Posted: Mon Aug 18, 2008 3:41 am Post subject: |
what would be the best option if you unplug the breather from the canister/intake manifold?
I've got TB's now so I can't hook the breather to my inlet (and I wouldn't want to)...
Let it hang loose in the engine bay could give a mess....I've seen filters put on the breather to filter any sucked in air...how essential would this be?
I'm surprised your cleaning made such a difference! how bad was the filth?
if your crankcase can't breathe the airpressure in the engine will rise (you wouldn't believe how much gas leaks past the piston rings) causing more resistance for the engine... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Mon Aug 18, 2008 8:43 am Post subject: |
My car was originally reg'd in NSW and Vic and then I bought it.
No canister but it may be the UK thing.
I connected my breather to the air box and plugged the join. Immediate change to the response of the motor.
I unplugged the breather and changed the hose awhile back.
I had oil leaks from the crank seal, the fill cap and probably the rear seal too before this. _________________ Porsche 924 1984 (UK import) NA
simsport
Posted: Mon Aug 18, 2008 9:01 am Post subject: breather |
Does anyone know if you can get the breather off the side of the block with the engine still in the car?
It seems to be shrouded by the engine mount bracket. I think my breather may be blocked.
Also are there more than one type? Mine seems to have the pipe in the middle but I have seen some with it canted over at the top.
Cheers
daveo
Posted: Mon Aug 18, 2008 9:12 am Post subject: |
Simon you can get it off with the motor in the car but its a bitch to get back on, you need the littlest hands on the planet but it is posible
Dave |
