Rob the plumber
Joined: 25 Aug 2008 Posts: 122 Location: Utica, Michigan
Posted: Tue Aug 26, 2008 8:29 am Post subject: Fuel gauge twitchy |
Is it a common issue to have a fuel gauge that bounces around and "ticks"? My temp gauge does it a little bit too, but the fuel gauge is all over the place. I just picked this car up yesterday, so I have a lot to learn.
Thanks!
Rob |
Posted: Tue Aug 26, 2008 11:28 am Post subject: |
Yep. Pretty common. You can address it by cleaning the grounds and also by cleaning the fuel sender, which our own (local to you and I) 924RACR published a how-to on.
Suggestion: list the model year and specific variant of your car (e.g. "1980 NA" for normally aspirate, "1982 931" for a turbo, etc.) in your sig so we all have easy reference to it when you post...guarantee, you'll never remember to remind us in all of your posts
Welcome aboard! There's a few of us here in SE MI...we need to do a fall get together soon...
{EDIT} Oops here's the link to the fuel sender fix: http://www.924.org/techsection/gas_sender.htm _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Aug 26, 2008 11:05 pm Post subject: |
try cleaning the external fuel sensor/float contacts before you pull the sensor out and clean it. A standard problem after all these years. _________________ 1979 924 (Gone to a better place)
AlexG
Posted: Wed Aug 27, 2008 7:47 am Post subject: |
Also check the condition of the shared earth point along the chassis beam at the rear of the car (i.e. between the rear lights) - after doing everything else I discovered this was where the fault was on mine  _________________ 924 2.0 NA |
Posted: Wed Aug 27, 2008 8:15 am Post subject: |
Here's the How-To
http://www.924board.org/viewtopic.php?t=24372
There's also instructions about for cleaning the sensor but try the simple stuff first. _________________ 1979 924 (Gone to a better place)
Rob the plumber
Posted: Wed Aug 27, 2008 10:59 am Post subject: |
| Thanks a lot for the help. I will do as suggested asap and get back with the results. |
