Ticking noise from top-end when cold
ourkid
PostPosted: Mon Sep 29, 2008 9:30 pm    Post subject: Ticking noise from top-end when cold Reply with quote
I thought at first this was from the cam/valve train area but a few of the lads at work are convinced that my ex manifold is blowing (expansion when hot calms it down).
I've removed the heat shield and cannot actually feel a blow from anywhere,although a couple of the nuts were quite loose.So,if i decide to fit a new gasket,what is the best way to plan removal as it looks like one hell of a job to get at the nuts.Do i need to access these from down below?
Thanks,
Ade.
1983 924 N/A
vexed73
PostPosted: Mon Sep 29, 2008 9:44 pm    Post subject: Reply with quote
Is yours N/A or Turbo? I have not tackled this job either but have the same problem according to my mechanic (brother). I am conflicted from doing a head job or a full rebuild. Seeing as how much of a pain the exhuast manifold is might as well do more and make it worth my while. I have the turbo model though.
1982 PORSCHE 931
Rich H
PostPosted: Mon Sep 29, 2008 11:06 pm    Post subject: Reply with quote
Its it a nightmare to move in situ, I would be inclined to tighten the nuts up and see if it fixes it.
Easyest way of finding exhaust leaks is to get it running and then get a willing volunteer to bung a ball of rags up the exhaust, any leak will then make a loud hiss (Then the ball of rags pops out or the engine stalls, don't do it for too long)
Rob the plumber
PostPosted: Tue Sep 30, 2008 1:00 am    Post subject: Reply with quote
Or use a length of tubing as a stethascope.
Slam
PostPosted: Tue Sep 30, 2008 1:20 am    Post subject: Reply with quote
On a regular NA you can change the exhaust manifold gaskets with the engine and head in the car. You can actually get to all the manifold nuts by reaching around under the manifold from above. Then pry the manifold away from the head, slip the new gaskets in and pop the nuts back on. I've done it. Chances are you'll find a couple of broken studs, in which case you've got a different problem and you will have to take the head off.
HTH
'88 944 Auto - may or may not resurrect
gohim
PostPosted: Tue Sep 30, 2008 5:38 am    Post subject: Reply with quote
Crawl under the car and check the bottom of the exhaust manifold for cracks.
Your 83 should have gotten the upgraded (reinforced with ribs cast on the bottom to help repvent cracks), but overheating the exhaust (excessive lean condition or too much timing advance) could have caused the exhaust to crack anyway.
The heat shield on the top of the exhaust manifold also has a tendency to crack and buzzz.
ourkid
PostPosted: Tue Sep 30, 2008 4:28 pm    Post subject: Reply with quote
Cool - I have the heatshield off now (it was cracked).
I'll have to get it over a pit.Looking at it now,if the bottom bolts are like the top ones,it just needs tightening up
Thanks.
1983 924 N/A
