flosho
Posted: Fri Oct 03, 2008 11:14 am Post subject: 931 Brake Bleeding |
Was bleeding my brakes yesterday, the driver side rear caliper bleeder screw was stripped, I got that free with a vice grips, only to find out that the bleeder screw is a "dummy" meaning it doesn't have a hole on the bottom side to allow it to bleed, it simply plugs the hole!
Is this common or was this the dreaded PO/quick lube fix to a previous issue!? _________________ [This Space For Rent] |
Posted: Fri Oct 03, 2008 12:10 pm Post subject: |
It should have a groove with a hole. _________________ White 87 924S "Ghost"
flosho
Posted: Fri Oct 03, 2008 12:33 pm Post subject: |
Yeah it doesn't.  _________________ [This Space For Rent] |
Posted: Fri Oct 03, 2008 12:39 pm Post subject: |
Or like this:
flosho
Posted: Fri Oct 03, 2008 12:50 pm Post subject: |
Yeah, looks like I need a new bleeder screw of four... _________________ [This Space For Rent] |
Posted: Fri Oct 03, 2008 1:42 pm Post subject: |
http://www.speedbleeder.com
Might as well make it easier to bleed while you're at it  _________________ Stefan
Posted: Sat Oct 04, 2008 5:31 am Post subject: |
Here are the two sets I got while trying to replace my rears. Neither was correct; the tips of the ones in the calipers were not pointed, rather hemispherical (as were their seats in the caliper body).
Useless information! _________________ Toofah King Bad
Min
Posted: Sun Oct 05, 2008 5:35 pm Post subject: |
we got a set from speedbleeders.com and sheared them right off trying to install them. Might wanna be careful of that product. The ones we got from russell performance went in no problems.
