Is this spark plug right?
Druman
PostPosted: Wed Dec 10, 2008 7:49 am    Post subject: Is this spark plug right? Reply with quote
Ok so for my 944 Auto Zone sold me a WR7DC but my owners manual says I need WR8DS, could this be causing my car not to start? My plugs are BLACK! Thanks guys.
7osh
PORSCHE pisses excellence...
PostPosted: Wed Dec 10, 2008 7:55 am    Post subject: Reply with quote
AZ vs. Porsche, I might be tempted to take Porsche's advice.
Druman
PostPosted: Wed Dec 10, 2008 8:50 am    Post subject: Reply with quote
yeah, I got some champions that crossed over to the correct number, but still nothing
7osh
ic932
PostPosted: Wed Dec 10, 2008 9:01 am    Post subject: Reply with quote
PET says WR7DC.....
PostPosted: Wed Dec 10, 2008 9:47 am    Post subject: Reply with quote
The one ending in "DS" is a silver plug, while the other ("DC") is copper (both are excellent conductors). -And there's only one heat range difference between the two. While heat range is important (you want the plugs to get hot enough to self-clean, but not so hot that they cause [pre-ignition ]), I seriously doubt that it's causing a no-start problem. Of course the black deposits on the plugs suggest a too rich mixture...maybe a bad o2 sensor?
Druman
PostPosted: Wed Dec 10, 2008 2:41 pm    Post subject: Reply with quote
Yeah, I tried a set of Champions that crossed over to the WR8DS, still won't start, I guess the next thing I need to check would be either distributor cap, wires, or coil eh?
7osh
Rich H
PostPosted: Wed Dec 10, 2008 6:29 pm    Post subject: Reply with quote
The plugs don't make much difference when starting as long as they are intact adn sparking, the heat range is more to do with later on after warm up is complete. Check the whole ignition system (Don't replace it of hand) all the way from the sparkers to the ignition unit.
Druman
PostPosted: Thu Dec 11, 2008 2:04 am    Post subject: Reply with quote
Thanks Rich, I'm gonna try the wires, distributor cap, and coil from my 924S to see if one of those is the problem. I wondered about the shims on the spark plugs tho, are they necessary on these cars? Could they be pulling the plug away from the piston to much?
7osh
PostPosted: Thu Dec 11, 2008 2:26 am    Post subject: Reply with quote
Unless the wrong range is used and they are rapidly fouled.
Druman
PostPosted: Sun Dec 14, 2008 5:30 am    Post subject: Reply with quote
Well I guess the spark plugs weren't the problem, it ended up being either a crankshaft or camshaft positioning sensor. Thanks for your help fellas.
7osh
mehall
PostPosted: Wed Dec 24, 2008 2:06 pm    Post subject: Reply with quote
How did you decide it was a crank shaft or sensor?
Black plugs seem indicate that they are fouled by too rich fuel mix.
Thanks.
Mark
Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org
Druman
PostPosted: Sat Jan 10, 2009 7:38 am    Post subject: Reply with quote
I changed it out of my 924S and it started working haha. When I took them out they were covered with blackness, I cleaned them put them back in and they still wouldn't work so I changed them. Hope this helps.
7osh
