Headlight mechanism
PostPosted: Wed Oct 20, 2010 10:50 am    Post subject: Headlight mechanism Reply with quote
I tried to be careful though it happened the springs became dislodged
in the headlight mechanism. If i could get a picture of how one side has the spring in place maybe i could get it from there. Is the spring under tension, The last piece of the linkage slips on to the head light inbetween the 2 prongs and the spring is supposed to slip on to the linkage piece this all held on by a plastic bushing that slides over the headlight holding bracket. Heres a pic of the pieces I assume there
a left hand spring and a right hand one.
mikebola
PostPosted: Wed Oct 20, 2010 12:07 pm    Post subject: Reply with quote
Oh wow, I had no idea the springs could come back off...
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
PostPosted: Wed Oct 20, 2010 3:22 pm    Post subject: Reply with quote
I need a picture.
mikebola
PostPosted: Thu Oct 21, 2010 1:35 pm    Post subject: Reply with quote
if nobody comes forward with a pic, I'll get you one tomorrow evening. I have an extra one sitting around in my shop.
joejax
PostPosted: Thu Oct 21, 2010 8:30 pm    Post subject: Reply with quote
Hey Joe, are you not going with the CGT headlight cover thingamajigs?
I got nothin'
Uhhh...you got any pics?
PostPosted: Tue Dec 07, 2010 3:04 am    Post subject: Reply with quote
Yea I guess though I need to get these headlights together if not
4 anything else then to put them in the other car.
* I need a pic. posted up of the assembly of my first pic
I posted. Please.
PostPosted: Tue Dec 07, 2010 5:18 am    Post subject: Reply with quote
Im wondering if theres ternsion of the spring that can only be reached with the jig mentioned in Haynes. I found a schematic that shows which side is up on the spring and thats about it. I think it cant be done am I wrong here. Com-on give me some help here. Though is designing and making fiberglass buckets what I want. ........... I think so.
Rattlinbone
PostPosted: Tue Dec 07, 2010 11:16 am    Post subject: Reply with quote
I'm having trouble with my headlight mechanism as well. I'm watching this thread to see if Mr. Joe924Racer figures it out. I don't think the Haynes manual has been much help. What about the big, fancy professional shop manual for this car, is there something in that that might help figure out how to get this put together properly?
Fred- 1979 924
Harm
PostPosted: Wed Dec 08, 2010 1:54 am    Post subject: Re: Headlight mechanism Reply with quote
Rattlinbone wrote:
… What about the big, fancy professional shop manual for this car, is there
Nope.
PET shows a diagram though.
PostPosted: Wed Dec 08, 2010 2:49 am    Post subject: Reply with quote
Hi all. So Im hoping this post gets kicked a picture today from
someone. The parts are waiting.
PostPosted: Wed Dec 08, 2010 2:50 am    Post subject: Reply with quote
PostPosted: Wed Dec 08, 2010 8:57 am    Post subject: Reply with quote
Outstanding. Cheers to the holidays.
Ill have to see how much tension is on the springs hence the doable
without a jig part.
PostPosted: Sat Dec 18, 2010 6:42 am    Post subject: Reply with quote
Grenadiers, man just wanted to thank you for posting thoe great pics.
Ive printed them out and am seing bout laying out the parts and getting them together just like in your pics. Thanks buddy want a life saver.
PostPosted: Mon Dec 20, 2010 1:24 pm    Post subject: Reply with quote
Seems Ive got it ,after placing everything like in the pics &
using a bar clamp I was able improvise a jig to set everything.
PostPosted: Wed Dec 29, 2010 6:46 am    Post subject: Reply with quote
How bout a pic of the springs location in the closed position
from anyone... you know the spring in the headlight mechanism
theres one on each side right by the inside attaching points.
Gren a diers buddy did you slap those together really quicke,
I solved the puzzle and put them together like in your pics
and guess what they wouldnt fit... seems the headlights need to be switched from side to side in other words there upside down.
I switched sides
installed them
adjusted them
Theres a problem theyll only go down to almost closed with the motor
(Im thinking the springs upside down and the tension is the wrong way.)
Resulting in them not closing.Ill have to reverse the tension of the spring
I guess.... its all trial and error.
