Early '24 sway bar upgrade?
Rich H
PostPosted: Sat Feb 16, 2008 12:05 am    Post subject: Early '24 sway bar upgrade? Reply with quote
Hey guys, I have had a search and can't find an answer...
I have a 1980 Euro spec 924 and I have fitted a rear roll bar off a '44 (As per the guide by Chrenan, thanks!) and I was hoping to uprate the front bar too but after having got the ARB mounts and an ARB off a later '24 it has become apparent that the chassis rails are different, my car has a beefy mount for the front ARB where the later bar bolts to the front chassis legs.
Are there any other stiffer factory bars that will be a direct fit? While its not too bad, its is clear the front bar is not stiff enough any more. I could chop the mounts about, should not be too hard but a bolt on would be easier!
PostPosted: Sat Feb 16, 2008 1:38 am    Post subject: Reply with quote
Biggest one is 23 (M471). What are you running now? The 23 combined with stiffer springs will probably get you where you want to go.
Rich H
PostPosted: Sat Feb 16, 2008 6:40 am    Post subject: Reply with quote
I will have to go and measure it, but its the standard one.
Ta
Rich
ic932
PostPosted: Sat Feb 16, 2008 7:27 am    Post subject: Reply with quote
i've got a M471 front bar from an 81' 931 which is the old style and will fit.
pm me if you are interested....
Vince Ponz
PostPosted: Sat Feb 16, 2008 11:32 am    Post subject: Reply with quote
I have a 25.5 mm front bar in the front. We mounted the bar under the A arm and relocated the long metal straps to the rails.
Works fine.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Browar
PostPosted: Sun Apr 05, 2009 7:01 pm    Post subject: Reply with quote
The biggest front sway bar in steel A-arms is 24mm from early 944 T .
Browar
eS
924 S `87
