Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Wed Apr 29, 2009 12:33 am Post subject: night time tail lamps |
Ok so I was about to swap cars out last night to get my car inspected this week when I noticed that I didn't have any tail lamps lit up. I started looking closely and noticed that my red tail lamps are only a single connection/single filiment bulb. My side markers on all corners light up and so do my licenceplate lamps.
Is the reflector the only thing on the back there for night time? or am I missing something here? It's not my inspection that i'm worried about it's my personal safety.
Tryp _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Posted: Wed Apr 29, 2009 1:11 am Post subject: |
The "tail lights" should come on with the running lights, first position and second position on the dash rocker switch. In stock form, they are on the same circuit as the running lights, so if the running lights and plate lights are on, and the wiring hasn't been cannibalized, you can eliminate fuses and relays as the issue.
First thing I would suspect is corrosion at the bulb holder itself. The tail lamps are susceptible to taking on water through the lens-to-body seal, and also due to the latch pin drain tubes being inadvertently disconnected, which will cause water to drip directly onto the bulb holder. Moisture in the lens assembly leads to corrosion.
Remove the rear bulb holder assembly, and thoroughly clean all of the grounds and power lead connections as well as the bulb holder contacts themselves. This is best done using a piece of 180 grit sand paper rolled into a tube to get into the circular shape of the bulb holder (which provides the ground). The bulb and positive contact (on the bottom) are easily cleaned with a flat sheet of sand paper or emory board.
Also, check the center grounding point between the tail lights behind the spare tire. _________________ erstwhile owner of just about every 924 variant ever made |
Power Tryp
Posted: Wed Apr 29, 2009 1:19 am Post subject: |
I forgot to mention that the brake lights work. Does any one know the industry # for the bulb that should be in the brake/tail lamp socket? i might just have an incorrect bulb? _________________ Melanie - 1980 931
Posted: Wed Apr 29, 2009 1:26 am Post subject: |
Brake light and tail light are two different bulbs, they are not the dual filament versions common on US cars of the era. The brake light is in the upper holder, and the tail light is in the lower holder. Don't recall the correct bulb part number off hand, but I'm sure someone here has access to the info. _________________ erstwhile owner of just about every 924 variant ever made |
Power Tryp
Posted: Wed Apr 29, 2009 1:30 am Post subject: |
So there's supposed to be a bulb in the section right below the reverse lamp? if so then i have a bigger problem than originally expected. _________________ Melanie - 1980 931
Posted: Wed Apr 29, 2009 1:36 am Post subject: |
| Power Tryp wrote: | | So there's supposed to be a bulb in the section right below the reverse lamp? if so then i have a bigger problem than originally expected. |
No, below the reverse light is blank and empty on a stock car. It is, however, a really nice upgrade to source a spare holder and splice in an extra bulb holder for added visibility.
I think I mistyped earlier...
You should have a yellow blinker on the top outside row, a white reverse light in the top center, a red tail light / running light in the bottom outside row, a blank red empty holder in the bottom center, and the inside position is a single large bulb. _________________ erstwhile owner of just about every 924 variant ever made |
Power Tryp
Posted: Wed Apr 29, 2009 1:51 am Post subject: |
So it's below the turn signal on the rear? I'm blanking here at the moment, I can't remember if there was a bulb there or not. It does make sense that there should be a bulb there, and I do like the idea of putting a bulb in the reflector spot. _________________ Melanie - 1980 931
RC
Posted: Wed Apr 29, 2009 1:57 am Post subject: |
| ideola wrote: | | Power Tryp wrote: | | So there's supposed to be a bulb in the section right below the reverse lamp? if so then i have a bigger problem than originally expected. |
You should have a yellow blinker on the top outside row, a white reverse light in the top center, a red tail light / running light in the bottom outside row, a blank red empty holder in the bottom center, and the inside position is a single large bulb. |
OK, thanks guys. Think this helps explain something I`ve wondered about and considered irrational.
Aussie cars have the brake light in the red bottom centre location and absolutely nothing at the inner all red square section. Not sure about ROW or Euro cars but interested to hear. Always thought that`s stupid and intend to (one day) fit an additional brake light there. The hole is there in the backing plate but no bulb holder. Easy to get one or fit LEDs.
So in USA it`s reversed. Brake light at the larger centre spot and a blank red at middle bottom. Thats more rational. Strange how the smart arse legislators in various parts of the world differ in their opinion on required safety. Dumb Wally may have put a light in BOTH sections but the Porsche accountants rejected it on economic grounds. As long as it passes the minimum required standard, I guess.  |
Posted: Wed Apr 29, 2009 2:00 am Post subject: |
Let's make it unequivocal:
(the above photo is from a US car, left hand side...obviously, reversed for the right hand side).
{EDIT}
I updated the description above after reading Roger's post...I didn't realized they were configured differently on ROW cars!!! Learn something new every day! _________________ erstwhile owner of just about every 924 variant ever made
Power Tryp
Posted: Wed Apr 29, 2009 2:09 am Post subject: |
perfect! alright, I my hunch is correct then I'm missing the tail lamp bulbs on both sides. Dan you've been a huge help, you should really write a book about these cars and make some money off all the hard work you've put into finding out the info that you have. sign me up for that.
Posted: Wed Apr 29, 2009 3:15 am Post subject: |
| Power Tryp wrote: | | you should really write a book about these cars and make some money off all the hard work you've put into finding out the info that you have. sign me up for that. |
LOL! Thanks for the kind words Actually, I've considered it and have a modest start on a book proposal...but I think I better finish the UWB project first Not sure how much money is to be made, given my narrow field of expertise and the limited audience, but it would be rewarding to have a tangible outcome from all of the research and reading! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Apr 29, 2009 3:31 am Post subject: |
isnt the bulb # something like 7038. I believe it is. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Power Tryp
Posted: Wed Apr 29, 2009 4:08 am Post subject: |
I noticed the PET lists two different bulbs back there, is the tail lamp bulb different or is it the turn signal bulb thats different? _________________ Melanie - 1980 931
xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Wed Apr 29, 2009 4:26 am Post subject: |
| RC wrote: | | Aussie cars have the brake light in the red bottom centre location and absolutely nothing at the inner all red square section. Not sure about ROW or Euro cars but interested to hear. |
My old Euro '77 has the same arrangement as the US cars, although it did have a bulb holder in the blank spot beneath the back-up lights that was wired up to the running lights. Dont know if that was modded or not by the P.O. _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
I can't remember off hand which is which, but one of them is definitely smaller than the other. It should be obvious when you look at how the backing plate attaches to the lens itself, as I believe the holes where the bulb end goes are different sizes as well. Sorry, no pix handy of the backing plate. _________________ erstwhile owner of just about every 924 variant ever made |
