Posted: Mon May 18, 2009 11:13 am Post subject: Guess What I Did this Afternoon |
 _________________ White 87 924S "Ghost"
Posted: Mon May 18, 2009 12:01 pm Post subject: |
I recognize the clamp on the power steering return line. Oops, I forgot to tell you about that! It leaks a bit! Were the old belts in Ok shape?
Now you can drive it like you stole it! Wait, I stole the 931!  _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
ic932
Posted: Mon May 18, 2009 5:50 pm Post subject: |
New belt installation Paul?
Or were you just checking the old ones. If so, how old and how far out of spec were they? |
JayZzzz4
Joined: 23 Sep 2008 Posts: 544 Location: Milwaukee, WI USA
Posted: Tue May 19, 2009 2:45 am Post subject: |
Alright Paul...... Your going to have to do mine now...  _________________ White 1987 Porsche 924S manual |
Posted: Tue May 19, 2009 11:20 am Post subject: |
Just taking a look at the belts to see what it needs. The used timing belt spec is 2.7 +/- .3 so it was extremely loose as evidenced by the first reading. Plus you can see rubber dust all over the cam pulley so this was a disaster waiting to happen. Just for fun and to check the spring loaded tensioner, I tensioned the belt to the correct spec.
I will be ordering new belts, etc. _________________ White 87 924S "Ghost"
Posted: Tue May 19, 2009 11:32 am Post subject: |
| Grenadiers wrote: | I recognize the clamp on the power steering return line. Oops, I forgot to tell you about that! It leaks a bit! Were the old belts in Ok shape?
Now you can drive it like you stole it! Wait, I stole the 931!  |
Your 80 931's name is Spike. He would appreciate that you update your signature.  _________________ White 87 924S "Ghost"
Slam
Posted: Tue Jun 09, 2009 4:12 am Post subject: |
I was going to say that it's probably no coincidence that the factory belt gauge has what appears to be a dollar sign on it... _________________ '88 944 Auto - may or may not resurrect |
Posted: Tue Jun 09, 2009 10:11 am Post subject: |
Ever loan that thing, Paul? _________________ Toofah King Bad
Posted: Thu Jun 11, 2009 7:02 am Post subject: |
DONE!!  _________________ '83 944 Track car.
Posted: Thu Jun 11, 2009 1:04 pm Post subject: |
Finished my version of the front service today (all four belts, all the rollers and tensioners). Also swapped out the oil pressure sender and now the gauge works. _________________ White 87 924S "Ghost"
Posted: Fri Jun 12, 2009 12:16 pm Post subject: |
Today I replaced the battery and the combo gauge (now the gas gauge works!). Also adjusted the parking brake. Also added some Dexron to the power steering reservoir. Took it for a couple of rides, now I need to find what is roaring in the rear end, _________________ White 87 924S "Ghost"
Ian924s88
Posted: Fri Jun 12, 2009 11:30 pm Post subject: |
I know my Transaxle in the back makes quite a bit of noise in neatral just idling. I changed my gear oil to Mobile one GL5 75/90 and it hushed it up alot.. it's been noisy since I've had it for a year and previous owner too ( just noisy transmissions ) I don't think its anything serious as it had got quieter if anything. Could be a wheel bearing in your case. _________________ 1988 Blue 924s |
Posted: Sat Jun 13, 2009 1:08 am Post subject: |
Hey Paul, I put about 5000 miles on that car since summer of '06, and it always made that noise. Not that I condone such behavior!  _________________ '83 944 Track car.
Posted: Sat Jun 13, 2009 3:18 am Post subject: |
At idle, Red's tranny sounds like a garbage disposal with a ball bearing bouncing around inside. It shifts great, though!
I decided to deal with the problem by not laying under the back of the car while it is idling, _________________ Toofah King Bad
Posted: Sat Jun 13, 2009 8:16 am Post subject: |
Hmm... getting the servicing up to date, and with only two weeks-odd 'til Keystone... might we see a white 924S in the Parade pic's this year? _________________ '80 924 Turbo |
