jack stands and clutch advice?
924turborox
PostPosted: Fri May 22, 2009 8:03 am    Post subject: jack stands and clutch advice? Reply with quote
is it alright to use a normal 924 clutch in a 1980 924 turbo?
and can someone please explain to me how to use jack stands properly?
i really dont want to damage the chassis of my car
thanks porsche community
v8carreragts
PostPosted: Fri May 22, 2009 9:10 am    Post subject: Reply with quote
You cannot use a 924 clutch in a 924 turbo. It is completely different. the 924 is a push type and 215mm in diameter with a 20mm x 24 spline hub and the turbo is a pull type with a 225mm diameter and a 25mm x 23 spline hub.
As for jack stands, I usually place them in back under the torsion bar tube and in front under the frame members just behind the firewall.
