McGuyver Award - Best use of non car part to make a repair
Goto page 1, 2, 3  Next
PostPosted: Wed Jun 24, 2009 2:48 am    Post subject: McGuyver Award - Best use of non car part to make a repair Reply with quote
This is for the 924.org McGuyver award -- the most unconventional use of conventional materials to make a repair.
What I'm hoping for is your feedback on the nuttiest non-car-part repair you've done to your car, found on your car, or seen someone else do. The idea is to post the situation, the non-car-part, and the result, if known. Pics are great if you have them.
A simple example: I used metal pallet band straps around my muffler to strap the whole thing together as it rusted to dust. The straps lasted longer than the muffler did, and got quite a laugh from the midas guy who finally replaced it about a year later.
I've seen/heard of beer cans, golf tees, drywall screw pots, rope, tin foil, cement, all kinds of things being used when innovation (ninnie-vation) intervenes in reality.
Whatcha got?
PostPosted: Wed Jun 24, 2009 2:58 am    Post subject: Reply with quote
This mob's semi-famous back home for doing that sort of thing. A clip...
Rich H
PostPosted: Wed Jun 24, 2009 3:27 am    Post subject: Reply with quote
Just wood screws to hold things on to the interior....
TurboBullet
PostPosted: Wed Jun 24, 2009 3:31 am    Post subject: Re: McGuyver Award - Best use of non car part to make a repa Reply with quote
my uncle(a plumber) once constructed an entire radiator-heater syetem out of copper pipe. truck ran for years with 0 issues.
Whatcha got?
87 Porshe 924s custom widebody
Martijnus
PostPosted: Wed Jun 24, 2009 4:23 am    Post subject: Reply with quote
I once used a soup can for replacing the end cap of my bike's muffler which I lost on the highway.
I also made a wooden gasket for my cylinder on my moped... lasted a while too
actually found a pic of that
edit:
an old sprocket was the bracket for my exhaust...
and later added the soup can with some drain material as an end piece
it rusted like hell. but it was becoming a rat bike anyway.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Harm
PostPosted: Wed Jun 24, 2009 4:30 am    Post subject: Reply with quote
Hmmm… MT …X?
Harm
PostPosted: Wed Jun 24, 2009 4:31 am    Post subject: Reply with quote
Hmmm… MT?
Martijnus
PostPosted: Wed Jun 24, 2009 6:14 am    Post subject: Reply with quote
Jup, a nice old MT5. Fun machine cheap, slow (was stock, have had it run 75km/h downhill ) but I practiced wheelies on it... had to find the right balance point because it didn't have much power...
That's about 20km/h or something like that could do that for a long time... was great fun. Now my neighbor has it. and it's even more crap than when I had it... at least it was technically fine when I had it.
moorepower
PostPosted: Wed Jun 24, 2009 6:42 am    Post subject: Reply with quote
I'm both proud and ashamed of this one:
I once had a power steering pump lock up on my '76 Ford Torino Elite. Since the belt that turns the steering pump also turns the water pump/fan, I had to rig something up to get me home from work.
At the time, I worked as a security guard at a mental hospital in PA. I found a bunch of old wheelchairs stored in an abandoned building on the grounds of the hospital. So, I "borrowed" one of the small front wheels from a wheelchair, removed the rubber tire, and voila! instant pulley! I used a bungee cord to keep tension on the belt, and it worked like a charm.
The guy who was on duty with me that night is probably still laughing about that one.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
PostPosted: Wed Jun 24, 2009 7:00 am    Post subject: Reply with quote
Conversation heard 'round the water cooler...
"So, what kind of head gasket do you have?"
"Oh, Steel custom made cometic of course. 51mm. Copper sealing spray. O-ringed the block. Raceware studs. Raised the compression 2 points. Absolutely top drawer. And you?"
"Me? Plywood, 1/4 inch. Thompson's Waterseal. Hose clamped the block. Working great so far. Had to use the 1/4 inch to lower the compression a little so when I put that turbo on, it'll kick a**..."
PostPosted: Wed Jun 24, 2009 10:41 am    Post subject: Reply with quote
I used one of these to hold the driver's door of my first car shut:
Rocco R16V
PostPosted: Wed Jun 24, 2009 11:43 am    Post subject: Reply with quote
I used a girls panties to tie up her exhaust so it wouldnt drag on the ground.
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
PostPosted: Wed Jun 24, 2009 3:26 pm    Post subject: Reply with quote
OT, but still McGuyverish -
Driving home from work in my long gone '74 Dodge van on a busy 2 lane secondary
road in rain-snow-slush, I pressed the clutch pedal and it went pop! No more
clutch releasing.. Pulled over, crawled under and found the 1/4" rod that links the
pedal to a lever that operates the clutch fork had worn through and snapped.
I removed the engine cover from inside, and found the long bar part of the olde
bumper jack. -Gave it a try (levering the bar against the floor opening to move the
clutch fork), decided yeah, maybe this can be done.. Pulled back into traffic and
drove the approx. 4 miles home from there operating the clutch with the jack bar
in my right hand, and steering and praying with the left. -And eyes popping
out exactly like this-->
PostPosted: Wed Jun 24, 2009 4:53 pm    Post subject: Reply with quote
I used an aluminum threshold plate for a house door to make reinforcing bars to straighten, strengthen, and support the rear cargo cover on the $100 95 VW Golf GL that I am using as a Daily Driver. I was looking at $75-$100 to buy a used replacement (probably heading the same way), but instead I spent $5 at the Habitat for Humanities Store for the threshold plate. Before repair the cover had sagged about 3" and was falling into the rear storage area under the rear hatchglass.
Slam
PostPosted: Thu Jun 25, 2009 4:01 am    Post subject: Reply with quote
The Hockey Puck Fix!
Surely that needs to be here.
Raise your hands, all who've done it.
Page 1 of 3
