944 sway bar onto 924
xdirtyx
PostPosted: Wed Aug 12, 2009 12:44 am    Post subject: 944 sway bar onto 924 Reply with quote
i have read on this site that its possible and has been done but after multiple searches i have yet to see a thread about anyone who has acctually done it. i have all necessary hardware ready to go ie: early 944 control arms, early 944 sway bar and all hardware....anyone that allready did this mod chime in with any advice before i start? thanks for any help its much appreciated
Rich H
PostPosted: Wed Aug 12, 2009 1:55 am    Post subject: Reply with quote
depends on which sway bar you have - if you have an early one then you need the mounting straps and to do a bit of chassis fabrication.
If you have the later ARB it'll bolt on AFAIK
Early arb bolts up tight to the chassis rails later one is on 2 8" long sraps that stand off the chassis rails.
Post a pic of what you have.
I got as far as getting the later ARB and fittings then gave up as it's probably not worth the effort chaning from early to late....
xdirtyx
PostPosted: Wed Aug 12, 2009 6:09 am    Post subject: Reply with quote
i have all early arms bar and hardware....coo it doesnt sound too hard then, what kinda chasis fab, are u familiar with what and where? thanks
Rich H
PostPosted: Wed Aug 12, 2009 6:15 am    Post subject: Reply with quote
You need to find a way to bolt the arb straps to the chassis rails and wishbones will need driling for the outer mounts.
Not convinced it's worth the effort though...
xdirtyx
PostPosted: Wed Aug 12, 2009 6:16 am    Post subject: Reply with quote
http://dcauto.gotdns.com/illustration/index/807141263
acctually that is what i have right there....am i wrong in thinking 82-85 is considered "early"?
xdirtyx
PostPosted: Wed Aug 12, 2009 6:19 am    Post subject: Reply with quote
and i have the 944 control arms allready mouted with the outer mounts....it was impossible for me to find 924 arms so we went with the early 944 arms thinking it was a direct bolt up.....oh well ill fig it out somehow
Rich H
PostPosted: Wed Aug 12, 2009 6:32 am    Post subject: Reply with quote
Number 2 in that pic just needs bolting onto the chassis legs somehow.
Rivnuts would probably be easiest if it meets the chassis legs square. Shouldn't be too much trouble.
xdirtyx
PostPosted: Wed Aug 12, 2009 6:51 am    Post subject: Reply with quote
ok ive now had it under the car checkingit all out, i jus got parts this morning so i hadnt got a chance to....looks pretty simple if u ask me...4 new holes and 4 new bolts....ill take some pics when completed, prob tomorrow
Vince Ponz
PostPosted: Thu Aug 13, 2009 1:22 am    Post subject: Reply with quote
I have the early A arms. I welded the L shaped straps to the inner rails. Attached the sway bar under the A arms.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
