Efi injector cup mystery solved
Mrpink
PostPosted: Fri Jan 08, 2016 3:47 am    Post subject: Efi injector cup mystery solved Reply with quote
I've been trying figure out what cup would bolt into the 924t head to convert the cis injectors to bosch electronic injectors. It took some digging and the answer is......... Vw part number 058 133 555
98 passat aeb engine code.
PostPosted: Fri Jan 08, 2016 5:54 am    Post subject: Reply with quote
thank you for sharing.
Britain
PostPosted: Fri Jan 08, 2016 5:31 pm    Post subject: Reply with quote
We just machined a cup into a transmission drain plug...worked out great.
-Britain
JjyKs
PostPosted: Sat Jan 23, 2016 11:07 pm    Post subject: Reply with quote
Damn, thanks for sharing, even though i already machined my head for direct fit. Well, maybe if i some day change to turbo head this will come to use.
PostPosted: Sun Jan 24, 2016 1:43 am    Post subject: Reply with quote
Where were you able to buy those? They don't seem to be readily available, although I haven't checked with a VW dealer yet...
Mrpink
PostPosted: Mon Jan 25, 2016 1:03 pm    Post subject: Injector cups Reply with quote
Readily available at the dealer
Now the real pain..... Getting the 60-2 wheel on the crank spocket
PostPosted: Mon Jan 25, 2016 1:06 pm    Post subject: Reply with quote
Why are you messing with a 60-2 setup?
http://garage.ideola.com/prod-EFISolutions.html#36-1TW
Mrpink
PostPosted: Mon Jan 25, 2016 1:12 pm    Post subject: Reply with quote
LOL "messing" that's what people do with cis! Though it works great but.....
I'm installing vems and it requires a 60-2 wheel
Mrpink
PostPosted: Mon Jan 25, 2016 1:21 pm    Post subject: Reply with quote
Another great efi solution would be to adapt the motronic system from a OBDII 2.0L vw golf/jetta. The swap would be super easy just need burn a custom chip. Again the 60-2 wheel would need to be made as well as modifing the distributor. On my rabbit this system made 240hp all day long and a/f ratios were very good. But..... If I'm doing that much work might as well go full stand alone
gabo931
PostPosted: Fri Feb 05, 2016 1:50 am    Post subject: Reply with quote
Thanks for sharing the find! I have couple of questions: Are these direct fit? And what type of injectors are you using?
1980 931 M471 LSD
Mrpink
PostPosted: Fri Feb 05, 2016 2:12 am    Post subject: Injector cups Reply with quote
Yes the cups are a direct drop in. I use bosch 44lb injector part# 0280155958
gabo931
PostPosted: Wed Feb 10, 2016 1:33 am    Post subject: Re: Injector cups Reply with quote
Thanks !
1980 931 M471 LSD
svinto
PostPosted: Sun Oct 09, 2016 7:38 am    Post subject: Reply with quote
037133555A seems similar and more available. Anyone tried them?
What would MacGyver do?
Mrpink
PostPosted: Sun Oct 09, 2016 7:54 am    Post subject: Injector cups Reply with quote
Won't work too small. the part number I provided is still available at the dealer
svinto
PostPosted: Sun Oct 09, 2016 8:37 am    Post subject: Reply with quote
06B 133 555 H seems usable too.
