xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Sat Aug 15, 2009 9:28 am Post subject: Carrera GT rear flares install |
Hey guys,
Im about to install the rear CGT flares. Only snag i ran into is cutting the rear arches. Can someone tell me how to go about this? I saw Hugo's diy but i have zero welding skills...
Xpernet _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Posted: Sat Aug 15, 2009 12:11 pm Post subject: |
Leadfoot's Going GT _________________ erstwhile owner of just about every 924 variant ever made |
xpernet
Posted: Sun Aug 16, 2009 10:10 am Post subject: |
sweet, thanks for the links Dan. So if i understood this correctly, the outer wall and inner well are close together when cut at 3" from the top. So i can weld them together at that point without the whole folding/bending stuff... But i have never welded before... Would JB weld work? _________________ 1977 Porsche 924
Sunroof Delete
Posted: Sun Aug 16, 2009 10:25 am Post subject: |
If you cut carefully and neatly, you could then use Flexible Edge Repair Panels like these...
...to avoid having to make your own folds, and then you could simply pop rivet these into place. I still haven't ruled out this approach on my car, but I may have to go another route because the PO butchered the OEM metal so badly, the gaps are probably too big for these strips. You would need to of these strips per side. _________________ erstwhile owner of just about every 924 variant ever made |
Vince Ponz
Posted: Sun Aug 16, 2009 11:57 am Post subject: |
Cut 3 inches and then weld them together and what I did was I FG the inside in case I missed some openings. Weld it, you don't want to make the body flex. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
joecitizennn
Posted: Sat Aug 22, 2009 12:06 pm Post subject: |
I used a reciprocating saw and welded the gaps shut. Take a sawzall to the side of a perfect condition original porsche with 74K miles on it??... spooky
Vince Ponz
Posted: Sat Aug 22, 2009 9:53 pm Post subject: |
yes, it is like operating on your son. You keep repeating "what did I do, what did I do" until you finish painting it. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Sat Aug 22, 2009 10:23 pm Post subject: |
| Vince Ponz wrote: | | You keep repeating "what did I do, what did I do" |
That's me everytime I touch my car...  _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
xpernet
Posted: Wed Aug 26, 2009 12:05 pm Post subject: |
Yeah... im currently having one of those WTF have i done moments...
I need to weld this, there is no other way going around this. Im thinking of buying a MIG welder on credit, and then returning it lol... i guess im going to learn how to weld as i go. Any suggestions/recommendation for welding & welding equipment?! _________________ 1977 Porsche 924
Sunroof Delete
flosho
Posted: Wed Aug 26, 2009 1:55 pm Post subject: |
Harbor Freight (Princess auto? in Canadia ) has cheap welders.. under 200 bucks.. _________________ [This Space For Rent] |
xpernet
Posted: Wed Aug 26, 2009 2:13 pm Post subject: |
Hey havent thought about that... crappy tire wanted well over 500 for a Mig... Ill check em out tomorrow morning.
TIG, MIG, or stick is the question though. I dunno which to choose, and which is better for a beginner. _________________ 1977 Porsche 924
Sunroof Delete
Posted: Wed Aug 26, 2009 2:20 pm Post subject: |
I don't think you want to learn how to weld on the body of your car. Sheet metal can be tough to weld for a beginner. Mistakes mean big holes in the metal where your fender used to be. _________________ 78 924 NA
5-lug |
Posted: Thu Aug 27, 2009 2:19 am Post subject: |
I bought my self-shielding wire-feed MIG from HF for right about $100. No gas. No muss. No fuss.
Make sure the metal is clean (grind then wipe with prep-sol or acetone) Clamp the two parts together then put spot-welds 1/4, 1/2, 3/4 of the way around, then split the difference between your original spots and keep doing this until you've filled in all the way around. Takes a while but it can work for a beginner. Grind down the bumps to smooth everything out and you're done. |
Min
Posted: Thu Aug 27, 2009 7:32 am Post subject: |
For a beginner, the easiest way to weld is with a oxygen acetylene torch. IMO anyways, it puddles really easily, and welds sheet metal very nicely, no splatter cleanup, no monkeying around, just a small tip and some tig wire.
