931 Head on 924
bacook
Guest
PostPosted: Mon Jul 30, 2001 12:06 am    Post subject: Reply with quote
Will I see a substantial increase in performance in my 924NA simply by swapping the stock head with a ported and polished 931 head? What else needs to change?
PostPosted: Mon Jul 30, 2001 12:23 am    Post subject: Reply with quote
Yeah, apparently so. I haven't done it myself, but I've heard from every big name out there that currently does or used to race 924's and it is the way to go. I'd do it on my racecar if it were legal
larso
Guest
PostPosted: Mon Jul 30, 2001 3:53 am    Post subject: Reply with quote
It won't work, you lose too much compression while gaining flow.
yada pistons yada.
yada injectors yada
yada spark wires yada
If you ever want to replace the valves on this 931 head on your 924, it now costs 50 dollars per valve rather than the 20 you were paying per valve before.
Just some thoughts to consider.
924 turbo
Guest
PostPosted: Mon Jul 30, 2001 10:00 am    Post subject: Reply with quote
You'll also need a turbo intake manifold. The studs are spaced differently.
-nick
Guest
PostPosted: Tue Jul 31, 2001 5:55 am    Post subject: Reply with quote
it is absolutely possible and has been done a number of times (ie the 924 DP cars). the benefit is that the 931 head flows better (engines are just pumps). it will require new pistons otherwise you will have very little compression. pistons are available from JE pistons. you'll need patience and a good $1500 clams to get it work right. but a considerable HP increase can be had.
or else you can change to a header and 9.3:1 pistons and have much more power than stock and spend half as much.
-nick
PostPosted: Tue Jul 31, 2001 9:45 am    Post subject: Reply with quote
Yeah, but ultimately, with the same setup, the 931 head still has more potential. The question is what your aim is; ultimate performance, or reasonable performance on a budget. For the latter, which I suspect you are after, the header and higher compression pistons are simpler...
eturbo924
Guest
PostPosted: Fri Aug 03, 2001 11:49 am    Post subject: Reply with quote
Take a look at a few of the articles on my site. http://www.geocities.com/eturbo924 click on the 924 Power tricks link. The one you want to read I believe is called indian red. It uses a 931 intake and head on a 924 NA block. I talks about all the upgrades he made to have a screaming 924. Cost a lot though.
Eric
daniel
PostPosted: Thu Sep 17, 2009 3:46 pm    Post subject: Reply with quote
Hey all
Does anyone know if there is another source of the performance upgrades on this site? They seem to have stoped working...
Cheers
Daniel
1989 944 Cabriolet
Martijnus
PostPosted: Fri Sep 18, 2009 1:40 am    Post subject: Reply with quote
8 yrs
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Fri Sep 18, 2009 3:03 am    Post subject: Reply with quote
I think he was asking about all the old historic articles that Eric used to have hosted on his site: http://www.geocities.com/eturbo924
The main site is up, but the articles are all 404.
Eturbo924
PostPosted: Sat Oct 03, 2009 8:35 am    Post subject: Reply with quote
I am in the process of reloading them. Unfortunately I lost my disc I had put them all on. So now I have to retype them all into htm files. whoops. Two are back up... the bolt on articles. I will go for Indian Red next. It is a great article.
Funny though... with the cross section that I think are on this site... where some one machined a 924 head to show what all the flow paths are like. I wonder if one went in and welded in some AL and smoothed out the correct spots... if the 924 head would flow better?
It seems there is too much turbulance in areas on purpose. To keep the NA 924 down. Was there not some one in Europe who did this and then went missing because he thoughts people were going to steal his research? I almost got one of these heads way back when .... alas I think it was when I was laid off and could not afford the ship costs. DOU!
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Sat Oct 03, 2009 5:08 pm    Post subject: Reply with quote
You should try http://www.archive.org/web/web.php. You should be able to plug in your website URL and a historical date, and see what comes up...they may have an archive of those pages that will prevent you from having to retype everything. You might be amazed at what you can retrieve...
...as for the head tricks, yes, absolutely, welding up the floor and changing the angle of the inlet would definitely improve the flow. According to John Brown, he's talked to a couple of old-timers who were doing mods on the 931 head back in the 80s, and that is exactly what they were doing.
