Transmission Rattle noise
xpernet
PostPosted: Sun Nov 22, 2009 5:48 pm    Post subject: Transmission Rattle noise Reply with quote
Whenever im in 3rd, i can hear a rattling noise from the back and it sounds like its coming from the transmission... it only does it in that gear. I know its the transmission because when im in 3rd and shake the stick shift a bit the noise would come and go. Any one know what that is? Im going to change the transmission fluid asap hoping that might solve it... i just hope its nothing major.
Thanks in Advance!
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
PostPosted: Mon Nov 23, 2009 5:13 am    Post subject: Reply with quote
Dont know hopefully a change of oil will remedy the noise though... it might.
JayZzzz4
PostPosted: Mon Nov 23, 2009 6:05 am    Post subject: Reply with quote
It could be your shifting linkage(s) by the transmission. Maybe the transmission makes a vibration only in 3rd gear?
White 1987 Porsche 924S manual
