isuras2
Posted: Sun Nov 22, 2009 11:55 pm Post subject: Rear Trailing Arm Removal |
I am trying to remove the rear trailing arm and have one stubborn bolt. It is one of the three that hold it to the spring plate. The two that are vertical came off just fine, but the third nut came off, but the bolt seems to be a larger (larger than 3/4 inch) bolt. Anyone know of which size that one would be? This is the last bolt that I need to get off, then I can remove it.
Thanks,
Rob |
Joined: 29 Jul 2001 Posts: 9122 Location: Royal Oak, MI, USA
Posted: Mon Nov 23, 2009 12:29 am Post subject: |
That's the eccentric for the camber adjustment. If you have the outer nut off, it's probably under some load and must be rotated to free it up. It's a through-hole, not threaded into anything, but yeah, stuck due to the loads perhaps. Size is 27mm. _________________ Vaughan Scott
isuras2
Posted: Mon Nov 23, 2009 12:54 am Post subject: |
I'll get a socket and see how it goes. Thanks Vaughan. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
924guy
Posted: Mon Nov 23, 2009 1:25 am Post subject: |
I used a bottle jack to "adjust" the plates to take the load off, worked like a charm... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
isuras2
Posted: Mon Nov 23, 2009 7:11 am Post subject: |
The 27mm (or actually I used a 1-1/16 inch) wrench worked. I have the trailing arm off, now just need to get the new one put on (with new wheel bearings!) hopefully tonight, then torque everything this week. I'll need an alignment eventually, but don't need the car on the road until after the winter. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
