Posted: Mon Dec 28, 2009 11:54 pm Post subject: Dual Port Manual Boost Controllers |
Functionally speaking, what is the difference between these two different styles of plumbing a dual port / tee style manual boost controller (MBC)?
 _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Dec 29, 2009 3:24 am Post subject: |
well the inline MBC that you have on the left uses a spring and ball system to keep the port open and then shut it at your dialed boost pressure.
The T boost controller on the right does not use a sprin or ball.
The screw has a cone shaped end that closes on a cone shaped body.
So the port is always open but because of the cone design and threaded advance-retract system the pressure can be regulated...how? i'm not 100% sure but i think that the thread and cone provide a VERY fine adjustment of the area between the body and the screw so more or less air can move trough.
in any case..it is known that the T style controller is way better for the system as it is not brutal ON OFF but has a fuzzy output signal. _________________ Supercharger and EFI kits
Posted: Tue Dec 29, 2009 3:33 am Post subject: |
morghen, you mentioned in the thread that yours was a Forge Motorsport product. Is this the one?
I don't see anything on their site that references the V- arrangement you've discussed here and in your other thread... _________________ erstwhile owner of just about every 924 variant ever made |
stevekat
Posted: Sun Jan 03, 2010 10:18 am Post subject: |
Looking at the diagrams, it is possible they are not necessary intended to be different. The second drawing could be intended as Morghen described, but I usually see discussion comparing the MBC diagram juxtaposed with a controller inline for a single port waste gate. The second drawing may just be a sloppy way of describing the first configuration when comparing it to a single port. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
