RichRod Guest
Posted: Sun Jun 02, 2002 11:08 am Post subject: |
Hello.
I need some help again. Just had the front strut assembly, front and rear disks and brakes pads, ac adjusting rod, reference mark sensor replaced. But now when I go over a bump on the road or just close the door on my car the engine looses power momentarily. I can see the RPM drop and immediately come back.
Thank RichRod
gohim Guest
Posted: Sun Jun 02, 2002 3:30 pm Post subject: |
| Since you just had your reference sensor replaced, I would start by looking at the connectors for the sensors. Maybe when you were changing one, you knocked the other loose, or you didn't get the one that you replaced plugged in properly. |
RichRod Guest
Posted: Mon Jun 03, 2002 3:23 am Post subject: |
| I had all the work done by a mechanic. Where do I find the reference sensors? |
Lizard Guest
Posted: Mon Jun 03, 2002 3:30 am Post subject: |
| take it back to the mechanic |
RichRod Guest
Posted: Tue Jun 04, 2002 9:57 am Post subject: |
| I found the fuel pump relay to be loose. |
