BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Wed Mar 31, 2010 8:22 am Post subject: New fuel pump makes it not start? |
I have been trying to get all the gremlins out of my CIS system forever. I have a rebuilt fuel dizzy.
New:
WUR
Injectors
Accumulator
Thermo Time Switch
I was previously running a fuel pump from a 951, but I was experiencing warm start problems. So I put in this fuel pump:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390149130189&viewitem=&sspagename=STRK%3AMEWNX%3AIT
which has higher pressure. Now I can't get the car to start. WTF?!?! I thought that maybe the higher pressure in would mess up the fuel mixture at the dizzy. So I took injector line 1 off at the dizzy and turned it clockwise until I got fuel just barely trickling out. No start. So I pulled the injector. The injector is not opening. If I remove the injector, I have fuel dripping out so I've got fuel to it. Is the injector just stuck closed or am I simply not getting enough pressure to make it open? Any feedback is appreciated. _________________ 1980 924 NA
1982 931 |
Posted: Wed Mar 31, 2010 10:05 am Post subject: |
do a fuel pressure and fuel flow test as per the haynes manual. _________________ Porsche 924 1984 (UK import) NA
BionicBalls
Posted: Wed Mar 31, 2010 11:16 am Post subject: |
Yea, I need to go ahead and order one up. Also looking for a CO tester for the fine tuning. Any brand suggestions? _________________ 1980 924 NA
1982 931 |
dpw928
Posted: Wed Mar 31, 2010 11:16 pm Post subject: |
Check our wiring to insure the connections aren't reversed. IIRC the positive connection goes on to the smaller post and the ground to the larger. If that is correct, perform a output volume test.
78 928 5 sp Silver
78 928 AT Euro Black |
BionicBalls
Posted: Thu Apr 01, 2010 12:59 am Post subject: |
You're correct. The pump is marked, and the positive uses a 7mm nut to secure it and the negative uses a 8mm.
With the 951 pump, I was getting anywhere from 0-2 bars of pressure upon start. With this pump, I'm getting 3-4 bars. I will check the volume output though. Is this pump meant to be used in conjunction with another pump? _________________ 1980 924 NA
1982 931 |
dpw928
Posted: Thu Apr 01, 2010 1:38 am Post subject: |
The pump listed was a 6 bar pump. It should deliver about 1100+ ML in 30 seconds. Have you checked the in tank strainer to see if it is plugged? Fuel filter plugged?
78 928 5 sp Silver
