flattened exh lobe on cyl 1!
the4ork
PostPosted: Tue Mar 30, 2010 3:16 pm    Post subject: flattened exh lobe on cyl 1! Reply with quote
took the valve cover off today and adjusted all the valves to about 4 thousandths, and noticed i have a smashed/flattened looking lobe on the exh side of #1
what could have caused that? all other lobes and lifters appear fine, the lifter on the messed up lobe looks a little chewed up. is it possible something made its way between the lobe and the lifter? something metal?
i just had the head rebuilt during a headgasket change so this is a suprise to me.
anyways, im in the market for a new used cam and lifter :/
its my girlfriends daily so i dont need anything fancy, although a cheap performance cam would be nice
Min
PostPosted: Tue Mar 30, 2010 3:39 pm    Post subject: Reply with quote
Oil without enough ZDDP content. And/or it was just time for it to fail. Unfortunately hardened parts like lifters and camshafts do not last forever, they are designed to fail eventually. But first make sure your running the correct oil, which is the most common cause of this problem.
Min
Rich H
PostPosted: Tue Mar 30, 2010 5:18 pm    Post subject: Reply with quote
As above - it's just life-ex it happens.
It is accelerated if the oil flow is interrupted but once the harded skin is worn through then they wear flat in no time at all.
the4ork
PostPosted: Tue Mar 30, 2010 5:35 pm    Post subject: Reply with quote
yeah she has let it get low on oil a few times... to the point the light was coming on.
ive been trying to figure out where its coming from. it looks like it drips down out of the cap, across the valve cover via the fins to the back of the sprocket, and then down the block. only when it runs.
changed the cap and it still does it, so it must be the valve cover gasket, which unfortunately is only like 3 months old
im running 20w50 shell oil in it
Rich H
PostPosted: Tue Mar 30, 2010 6:29 pm    Post subject: Reply with quote
check all the crank case breather hoses are still intact, they heal over or rot in time.
Min
PostPosted: Tue Mar 30, 2010 11:23 pm    Post subject: Reply with quote
Check your oil for zddp content, contact the manufacturer about it.
Min
PostPosted: Tue Mar 30, 2010 11:29 pm    Post subject: Reply with quote
The other big cause of this is a failed cam oiler tube, or more frequently, the little plastic elbow that connects it to the first cam bearing cap. If the elbow develops a crack, it will bleed pressure from the oiler tube, which in turn results in improper oil flow across the cam and lifters. You should carefully inspect your other lifters and cam lobes for any signs of wear. I would strongly recommend replacing the elbow at a minimum ($12.50 from yours truly), and verifying that the tube itself isn't clogged or otherwise compromised. It's also time for a new cam and lifter in that bore. If you don't want to buy new, I have secondhand OEM cams and lifters available (but not listed in my used parts bin...contact me via PM if interested).
gla924sem
PostPosted: Wed Mar 31, 2010 12:20 am    Post subject: cam Reply with quote
Have a stock cam with about 12K on it. Replace it with an Intergal Race cam.
Does not have the cam gear.
Will let go for $75 plus shipping from 48180
Can send pics
Slam
PostPosted: Wed Mar 31, 2010 1:31 am    Post subject: Reply with quote
I agree about the cam oiler elbow, but when that fails, doesn't the wear usually show up on lifters 7 & 8? Having a failure that close to the elbow is rare.
PostPosted: Wed Mar 31, 2010 1:42 am    Post subject: Reply with quote
I had the exact same lifter and lobe damaged on the 941, although in my case I don't believe it was due to the elbow. In my case, it appeared that the coily retainer thingy on the valve guide seal let go and got loose in the head. Although some here doubted it caused the problem, and hypothesized that it was due to one of the aforementioned causes.
Still, the elbow is easy to check, easy to replace, and cheap.
the4ork
PostPosted: Wed Mar 31, 2010 8:30 am    Post subject: Reply with quote
I know it's not the elbow, oil flows prettywell in the tube, thy was my first guess.
I think it's from low oil pressure from runnin the oil level too low or foreign debris
anyone got a free cam and I'll pay shipping?
ithink there is a 924 at the yard, cams are like 15 bux I think
PostPosted: Sun Apr 04, 2010 7:54 pm    Post subject: Reply with quote
You could for 150 bucks send it to schnieder racing cams and theyll
weld and gring up a new hotter gringd on the one you have. Ited be best to give them a cam that hasnt lost its hardness if thats the issue. Ask if you go that route. theyll maybe reharden it for you dont know if thats an issue.
