hood scoop install
ZODIAC
PostPosted: Mon Mar 08, 2010 3:56 pm    Post subject: hood scoop install Reply with quote
if the weather is still good on tuesday(my day off) i'm going to try and install my new GT hood scoop. my question for those of you who have installed them already is, should i get some rubber or something to make a gasket to go between it and the hood? it didnt come with any instruction, just the scoop and the screws to hold it on.
"Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color...
PostPosted: Tue Mar 09, 2010 12:12 am    Post subject: Reply with quote
I have a GT Racing hood scoop on my car, but it has an edge all the way around it. I went with the 'industrial' look (meaning, lazy), and riveted it on. I like the look, the hood has been painted to match since this photo. I did not use a gasket between the hood and scoop.
ZODIAC
PostPosted: Sun Mar 14, 2010 2:17 am    Post subject: Reply with quote
mine doesnt have that lip around it and it dips down in the front so i have to cut the hood a little more to accomodate for that. but it has holes in the underside that are threaded for screws that came with it. i figure i'll just put a layer of RTV on it to help hold it in place and reduce friction between it and the hood.
Carrera
PostPosted: Thu Mar 18, 2010 7:50 pm    Post subject: Reply with quote
Zodiac, unfortunately I haven't installed mine yet, but mine looks identical to yours. I bought mine used on eBay and I don't have a clue on which "brand" it is. May I ask which brand yours is?
Any pointers and experiences on the installation would be highly appreciated
I'll actually have the hood cut by the painter in mid April...
In case you have a standard normally aspirated cars hood (not 931 hood), some measurements on the hole on the hood would also be appreciated.
On the original 937 scoop there is a round "rubber band" that goes around the scoop... there is an original 937 for sale at the shop where I have my cars serviced, so I had a closer look at it
931 S2, 1981
PostPosted: Fri Mar 19, 2010 12:13 am    Post subject: Reply with quote
Is the 'rubber band' under the hood? Then, that's to seal the intake ram to the top mounted intercooler. I have said TMIC and used foam! Butt-ugly, but the oem rubber is very expensive, if even available.
Carrera
PostPosted: Fri Mar 19, 2010 1:39 am    Post subject: Reply with quote
Nope... its visible on top of the hood though its been painted over. Having said that, although this example is in pristine condition, it is anyways 29 years old, so I can not guarantee its still in its original form... and I haven't yet seen what it looks like under the hood.
Here's a picture of a replica also with a rubber band, but now more visible as it hasn't been painted over.
931 S2, 1981
PostPosted: Fri Mar 19, 2010 2:20 am    Post subject: Reply with quote
If you were going to go to the trouble of respraying a real Carerra GT (or even a decent facsimile of one), why in the interest of all that is good and beautiful would you not go to the minor trouble of removing the scoop and the gasket?????? Man, I don't get it.
On a related note, you wouldn't believe some of the stuff we found on my 941 when my paint guy started doing the prep. But that's another story
Carrera
PostPosted: Fri Mar 19, 2010 4:59 am    Post subject: Reply with quote
Dan, do you know what the original scoops "rubber band" set up should be? The 937's I've seen don't seem to have black rubber on them... I admit the red one is the only one I've seen live...
931 S2, 1981
PostPosted: Fri Mar 19, 2010 5:04 am    Post subject: Reply with quote
Admittedly, I do not know what the stock config is, but I was under the impression that it had the seal, not in body color, atop the hood like in the Yellow car example. Don't know why I have that impression, and it could be completely wrong...
...would have to dig through my photo archives to see if it reveals anything...gotta run in 5 minutes, so will have to come back to this later tonight...
ZODIAC
PostPosted: Fri Mar 19, 2010 8:27 am    Post subject: Reply with quote
carrera; my car is an n/a but i have a custom intake manifold and downdraft carb setup. the entire CIS and original intake configurations have been removed before i bought the car. as for the brand it was advertised on ebay as being a GT raceing scoop, but i dont think it is.
i'll be posting pics of the install, i plan to hit it on sunday. i think i may try and get some thin rubber gasket material and make a gasket for it, or a good layer of RTV.
as far as measurments, i already have a roughly 12"x12" hole cut for the carb. my plan is to align the top right corner of the scoop (looking at it from the front as in my pic) with the top right corner of the cut in the hood. then just cut a section out for where the scoop dips down in the front.
hope this helps.
pcelenta
PostPosted: Sun Mar 28, 2010 10:34 pm    Post subject: Reply with quote
guys the factory welt seals for the hood scoop were available in body color. some of the colors are NLA. Just last year I purchased the welt seals for the rear flares and for the hood scoop of my car direct from my porsche dealer who had them fedexed from germany. On the PET you can see the part numbers and the colors...I ordered mine in silver as it had been originally equiped with. The aftermarked GT Racing CGT hood scoop pictured here has the flange lip going the wrong way...on the originals it is hidden underneath the scoop and has holes to bolt it to the hood. the seal is sandwiched betwwen the hood and scoop before bolting it. regards, Paul (mystery CGT project pictures comming soon!)
joecitizennn
PostPosted: Sun Mar 28, 2010 11:34 pm    Post subject: Reply with quote
be careful using silicone on a surface you plan to paint
Vince Ponz
PostPosted: Mon Mar 29, 2010 12:51 am    Post subject: Reply with quote
I kind of like the black showing under the scoop. Brings attention to it.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Carrera
PostPosted: Mon Mar 29, 2010 3:09 am    Post subject: Reply with quote
pcelenta wrote:
guys the factory welt seals for the hood scoop were available in body color...
That was good information!
My scoop is not original, looks identical to ZODIAC's scoop though. I do have a flange lip but it does not have holes to bolt on the hood... but in order to be able to bolt it on from the flanfge you shoud also have a factory original 937 hood ... which I don't have...
Lets hope the scoop will hold with the seven locking nuts.
The silver welt seal is still available from the factory. At least the Porsche Classics page shows they have them in stock for about 15€ ($20).
Part number: 937 571 121 01 and then 97A for silver.
My car happens to be platinum so a silver seal is a no-go... blck would have been ok...
There is yet another seal for about 10€ ($14), part number 999 911 276 40. Don't know where this is supposed to go... no picture in PET.
What I would still need is the IC seal that goes under the scoop. Part number 937 511 113 00. That one doesn't seem to be available anymore...
931 S2, 1981
reilly525i
PostPosted: Sat Apr 03, 2010 1:57 am    Post subject: Reply with quote
while doing a very similar functioning scoop on my old mk2 I used a length of door edge trim. it looked perfect, gave you a good snug mating surface and cost about 4 dollars at pep boys. it looked exactly like that yellow cgt there.
"There are no kings inside the gates of Eden"
80 n/a 924.
76 alfa romeo spider
e34 525i.
xj6 vanden plas
vintage Sunbeam 6 speed bicycle
