933 and 928 calipers
FSMITH010
PostPosted: Sat May 16, 2009 9:27 am    Post subject: 933 and 928 calipers Reply with quote
I read that the 933 used 928 calipers.
Has anyone tried this or are the period 928 calipers no better than 931 or 944 calipers?
PostPosted: Sat May 16, 2009 9:40 am    Post subject: Re: 933 and 928 calipers Reply with quote
Where did you read that?
The D-Prod parts list at 924.org for the 933 indicates same-era 930 calipers, of which I have a pair. It's possible that a 1980 928 used the same calipers as a 1980 930, but I haven't cross-referenced PET to find out.
In any event, it's a moot point, because you can't bolt up the calipers that were used on the 933 to a 931. The caliper bolt pattern is 89mm vs. the standard 76mm for 931/944 (non-M030) calipers. More details and photos here.
FSMITH010
PostPosted: Sat May 16, 2009 10:39 am    Post subject: Re: 933 and 928 calipers Reply with quote
bah. forget, last night somewhere I could try and find it again.
Ya, that is what I figured as I read it since I had read 930 also before. Actually the calipers and rotors aren't on that list anyways.
that would just require different carriers right? tried the 930 carriers or 928 carriers?
PostPosted: Sat May 16, 2009 11:02 am    Post subject: Reply with quote
I assumed you were referring to the fronts. AFAIK, the rear caliper spacing is the same for all of the rear disc-based 924/931/944/951 calipers (e.g. the Brembos have the same bolt pattern as the single pots in the rear). The front calipers are where the problem lies. The 933 apparently had its own custom spindle (at least based on the part number). So you would either need 933 spindles, or you'd have to develop a custom adapter bracket. Hardly worth it for bolting up 30 year old calipers design. If you went to the expense and trouble of fabbing/purchasing adapter brackets, might as well go with Wilwoods or the Brembos.
PostPosted: Sat May 16, 2009 2:08 pm    Post subject: Reply with quote
FWIW, I ran the part numbers mentioned by Dan in the other thread about 933 brake parts, and the calipers came back as late 70s/early 80s 911 SC calipers, which are two pot, and still available new for a reasonable sum.
williamoss
PostPosted: Mon Mar 15, 2010 7:52 am    Post subject: 928 brakes Reply with quote
On my car a street model D production Sebring which came with 4 disks and a 5 bolt pattern it had 928 brakes. They worked great. The only propblem was when I went to buy pads and they asked what model car I had and I replied a 924 then told them I need the 928 pads there was alwasy a discussion untill the parts department looked at the car and then they sold me the 928 pads. It wa a funny bbut true story one of many of that great car.
William Moss
Tigard OR
leadfoot
PostPosted: Mon Mar 15, 2010 12:13 pm    Post subject: Reply with quote
have seen them on an S "as in sports model" came with trash can rims.
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
gegge
PostPosted: Tue Jun 08, 2010 9:04 pm    Post subject: Reply with quote
According to the FIA document, the Gr.4 homologisation for the 924 was with 48mm 2-pot callipers in the front. Just like contemporary 911:
Caliper typ M 69-76 76mm c-c
Caliper typ A 76-83
Caliper typ S 84-89
'A' calipers are stiffer than 'S'
Check page 18:
http://hms.dk/downloads/homologering/3075-Porsche.924.pdf
Carl Fredrik Torkildsen
PostPosted: Wed Jun 09, 2010 4:46 am    Post subject: Reply with quote
I believe this is correct. I have a pair of these calipers, in steel, and the mounting holes match the toofah spindle. Also of note, the vented rotor is the same part as the 911.
