924 starter motor how to change it
mini-neil
PostPosted: Sun Apr 11, 2010 3:37 am    Post subject: 924 starter motor how to change it Reply with quote
has any1 got any info on how to change the starter motor?
mini5721@hotmail.co.uk
mini-neil
Rich H
PostPosted: Sun Apr 11, 2010 5:01 am    Post subject: Reply with quote
Disconnect the battery!
Put it up on sticks or ramps
Remove the undertray (If fitted)
Unbolt the main cable
Undo the 2 bolts and remove the starter...
It's heavy so mind your head!
the_mad_electrician
PostPosted: Mon Apr 12, 2010 1:36 am    Post subject: Reply with quote
It took me about 30 minutes to change mine. 45 if you inclide the time to go get my tools and the jack.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
owenexile
PostPosted: Mon Apr 12, 2010 2:27 am    Post subject: Reply with quote
What he sed , But its Absulutly Crucial to Disconnect the Battery
924 1982 N/A
For some reason theres always a earth problem somewhere with this car...
931Owner
PostPosted: Sun Apr 18, 2010 3:17 pm    Post subject: Reply with quote
Shouldn't the starter just slide back and off the bell housing? I've changed many a F-150 starter but I can't get it to budge. I've even taken a rubber mallet to it, it still will not move!
1980 Turbo
-too many cars and too many motobikes
Tas931
PostPosted: Mon Apr 19, 2010 9:42 am    Post subject: Reply with quote
Yeah i had to give mine a few love taps to get it out
mini-neil
PostPosted: Sat May 15, 2010 5:46 am    Post subject: You all had it easy lol Reply with quote
I having trouble with the last bolt on the exhaust at the 4-2 joint 4 out of 5 came off fine, have to take it and the shielding of cos the bolts have siezed so have to do it the hard way, im getin a click out of the starter eve time i turn the key is it caused by a bad earth?
mini-neil
PostPosted: Sun May 16, 2010 12:40 am    Post subject: Reply with quote
My usual first suspect with a click but no start is a bad starter solenoid - and specifically, corroded switch contacts within the solenoid. The starter has to come out to change it.
Other possibilities are weak battery and/or poor connection/s at battery, alternator, grounds,... This stuff's easier than replacing the solenoid, so I'd have starter with them. -And of those, start with battery connections - remove, clean, re-attach..
Next try jump-starting.
-But you can have several problems at once - poor connections, and/or weak battery, and/or partly corroded solenoid switch, and sometimes improving just one might be enough to get it started, but just barely, so should go through it all and make sure everything's right.
931Owner
PostPosted: Sun May 16, 2010 5:49 am    Post subject: Reply with quote
I second Smoothie's analysis!
1980 Turbo
PostPosted: Sun May 16, 2010 6:22 am    Post subject: Reply with quote
You guys have it all wrong! After disconnecting the battery, you put the car on a car lift! In this pic, I'm currently double parked. And no, I didn't stand on the stool to open the door!
Here's an over-exposed shot of cars, and all the metal shelving we recently put in. Most of the shelving space on the right has 931 parts on them!
Scorpio
PostPosted: Sun May 16, 2010 12:39 pm    Post subject: Reply with quote
Ok im buing a car lift one day!
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
Slam
PostPosted: Tue May 18, 2010 1:34 am    Post subject: Reply with quote
You get more room to pull the starter if you remove the oil filter first. It's a good time to clean up/fix the wiring down there. Check out the harness from the battery that snakes down the firewall to the starter and also check the wiring from the starter to the alternator.
RC
PostPosted: Tue May 18, 2010 3:11 am    Post subject: Reply with quote
You also get more room without the oil filter adapter and the steering shaft in the way. Much easier than a RHD car. Stop whinging pussies!
PostPosted: Tue May 18, 2010 5:22 am    Post subject: Reply with quote
This is for you RC:
http://www.youtube.com/watch?v=unkIVvjZc9Y
paulsmaroon924
PostPosted: Tue May 18, 2010 8:36 am    Post subject: Reply with quote
its in the haynes manual but in mine i had to take off the 2 into 1 section of my exhaust for access to some of the housing strap bolts, put simply it a #### of a job to do in your driveway, we managed but it was a real pain without a lifter for easy access
