931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Mon May 17, 2010 11:52 am Post subject: In your face gauges for a 911 turbo,will they work on a 931? |
Hey folks
I noticed these cool gauges but for a 911. Could we use them on the 931?
http://www.inyourfacegauges.com/osc/index.php?cPath=23_30 _________________ 1980 Turbo
-too many cars and too many motobikes |
Posted: Tue May 18, 2010 5:33 am Post subject: |
Not sure if the 911/930 stuff is interchangeable with the stock 931 gauges. However, two thoughts:
1. The combo tach / AFR gauge they show requires you to send your tach in for retrofitting. No reason that couldn't be done with the 931 tach. Only issue I see is that the AFR gauge will be in an odd spot due to the conveniently upside-down orientation of our tachs.
2. Looks to me like they're repackaging PLX Devices components. Those are almost for sure PLX control modules combined with their multi-gauge technology. So that said, you could probably just get the bits from PLX and modify your own gauge and save a few bucks in the process. _________________ erstwhile owner of just about every 924 variant ever made |
