931 Brain Fart Assist
PostPosted: Tue May 18, 2010 3:57 pm    Post subject: 931 Brain Fart Assist Reply with quote
Downpipe goes on before wastegate, right?
stevekat
PostPosted: Tue May 18, 2010 5:46 pm    Post subject: Reply with quote
You mean J-Pipe? Depends what is on and what's off. Just recently replaced waste gate and J-Pipe. Recall having to keep things loose. Inserted dump pipe into cat or cat bypass and attached waste gate, then recall putting on J-Pipe, and needing some maneuvering room. All the while the waste gate was loose on its mounts - suggest keeping waste gate loose until all pipes are snug, so as to reduce stress on mounting hardware for waste gate. Need some good extensions and universals to get in to waste gate bracket near torque tube. Think about pulling heat shield to tighten waste gate bracket nuts. This from memory however, with inherent flaws of recollection. Did not have exhaust pipe off of turbo for this work.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
PostPosted: Wed May 19, 2010 1:45 am    Post subject: Reply with quote
Jus pushed print.. r ya excited rasta big guy.
PostPosted: Wed May 19, 2010 11:23 pm    Post subject: Reply with quote
Large header pipe, then attach the pipe from the WG to the cat to the WG. Insert pipe into the cat and loosely install the WG on the header pipe. Then install the J pipe.
Leave everything loose until all is installed.
