Paint work: Remove run with razor blade
bnoon
PostPosted: Mon Jul 19, 2010 6:09 am    Post subject: Paint work: Remove run with razor blade Reply with quote
4 Video play list on YouTube.
Thought I'd do a little "How To" to show the razor blade method to removing a run in the clear coat. Let it dry 3-4 weeks and give it several hot days in the sun or under bake lamps to ensure the drips are dry all the way through or you'll take chunks out. Wet sanding after this method, then polishing compound steps to bring back the shine.
'80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless
PostPosted: Mon Jul 19, 2010 2:47 pm    Post subject: Reply with quote
Have you finished it yet.. thats a good trick.
bnoon
PostPosted: Tue Jul 20, 2010 2:13 am    Post subject: Reply with quote
Started block sanding, but not done yet. It was hot and humid with a heat index well into the 100's, so I had to lay off for the rest of the day. Not to mention that I rode 25 miles on my Mt. bike prior to starting this work, LOL!
Porscheless
