rkn
Posted: Thu Jun 03, 2010 8:17 pm Post subject: New steering wheel - poor fit |
so here is my newest issue, I just bought a 3-spoke 924/944 wheel to replace my 2-spoke. I was surprised to find that the part that fits on the steering column was too big!
I had done a bit of searching beforehand and had read several places that all these wheels are interchangeable...guess not! So I had to drill out rivets and swap the connector from the old 2-spoke wheel.
All is good (I thought)
But then the next problem showed up - the plastic cover of the wheel is also bigger than the old one! This means that the washer arm has no room to be activated, as you can see in this pic:
Has anyone had this experience before? Can I mount a different kind of washer/wiper stalk? I know the newer switches have "straight" arms, but will they fit on mine? Any good ideas would be appreciated... _________________ 1980 924NA ROW |
dpw928
Posted: Thu Jun 03, 2010 10:35 pm Post subject: |
What you received appears to be a 928 steering wheel, which is larger. A lot of sellers on Ebay aren't aware of the differences and advertise them incorrectly.
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Fri Jun 04, 2010 2:57 am Post subject: |
break out your dremel and masking tape. Tape the area off that you want to cut and carefully trim the plastic back. Sand the edge down with a sanding drum or a piece of sand paper until you get the look you want and maybe hit the edge with some black vinyl or plastic paint. _________________ Stefan
Rich H
Posted: Fri Jun 04, 2010 7:47 am Post subject: |
Get later stalks...  _________________ 1994 Lotus Esprit S4 - Work in progress...
rkn
Posted: Fri Jun 04, 2010 9:23 pm Post subject: |
| Rich H wrote: | Get later stalks...  |
So the later ones are plug-and-play?
Posted: Fri Jun 04, 2010 11:14 pm Post subject: |
Not those kind. Those look like 944. My '81 has similar stalks, but I don't recall the plug interface looking like those...although it has been probably 5 years since I had it apart, so I don't trust my memory. _________________ erstwhile owner of just about every 924 variant ever made |
