OIL EVERYWHERE!!!!!
1979*924
PostPosted: Mon Jun 07, 2010 1:59 am    Post subject: OIL EVERYWHERE!!!!! Reply with quote
Good morning everyone. Well everything was going just fine with my 1979 924na, until the other day when I was headed to work. I got in and started it up and headed down the road. About a 1/2 mile into my trip, I noticed the oil pressure was going lower as I was going faster. . I let of the gas, pulled over, and turned the engine off. When I opened the hood and got out, there was a BIG oil puddle under the engine. I have determined there are no holes in the block, or oil pan, so I assume it's from the oil pump. My question is can the oil pump and associated seals by removed and replaced while the engine is still in the car? What seals or gaskets would I need? How hard would this be? Any help would be greatly appreciated. Thanks in advance.
PostPosted: Mon Jun 07, 2010 9:15 am    Post subject: Reply with quote
dont assume anything, the filter may be loose.
1979*924
PostPosted: Mon Jun 07, 2010 11:39 am    Post subject: Reply with quote
I checked the filter, couldn't be so lucky . Again what seals and or gaskets would I need?
931Owner
PostPosted: Mon Jun 07, 2010 12:04 pm    Post subject: Re: OIL EVERYWHERE!!!!! Reply with quote
1979*924 wrote:
...I noticed the oil pressure was going lower as I was going faster.
Good observation skills there... it would have been BIGGER problems if you weren't so vigilant and stopped as soon as you noticed the low pressure.
1980 Turbo
-too many cars and too many motobikes
PostPosted: Mon Jun 07, 2010 12:16 pm    Post subject: Reply with quote
Illustration 104-00 in PET.
Front main sealing ring: 048.115.147
Oil pump gasket: 046.115.189.A
Yes, I believe you can replace them both with the engine in the car.
However, I find it hard to believe you would blow that much oil that quickly with no warning from that part of the engine.
There are two flex gaskets at the front and rear of the oil pan (not the pan gasket itself, but part of the kit). Are you sure those are OK? Is your crankcase breather hose still attached? No chance your blowing oil out of it? They get old and dry rot after a while, could have been holey for some time, but if you developed blowby, it could be spewing out of there, or even the dip stick tube...
1979*924
PostPosted: Mon Jun 07, 2010 1:07 pm    Post subject: Reply with quote
Thanks for all the responses. I guess I need just get in there and get my hands a little dirty before I order any kind of parts. I'm sure I have a few more questions in the days to come. Thanks again. And if anybody has any other ideas, just let me know.
PostPosted: Tue Jun 08, 2010 1:58 am    Post subject: Reply with quote
I had that before, i forgot to put the lid back on after refilling some oil......
I was lucky,found the lid and after cleaning the e-bay for hours everything was nice and clean........
Vince Ponz
PostPosted: Tue Jun 08, 2010 11:55 pm    Post subject: Reply with quote
I did not tighten the oil filler cap twice and got oil all over the place.
Once at the track. Funny looking in your rear view mirror and seeing all the smoke and the car is running perfectly. No oil cap was the problem. Too much in a hurry to get back on the track to notice.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Wed Jun 09, 2010 1:41 am    Post subject: Reply with quote
Hey man... cool car you gotta show me your custom nose panel vent
covers..with a pic. You seem not 2 know if its the pump or not
to me that compounds the job.. it would be nice if you were able to
keep it in the car (the motor). Ive done pan gasket replacements
with it in the car. Kind of a pita. God luck, give us some pics.
Martijnus
PostPosted: Wed Jun 09, 2010 2:40 am    Post subject: Reply with quote
I'd advise to firstly determine where the oil exactly is coming from.
It's mentioned above... but you'll do more damage, spend more unnecessary time and money if you don't exactly know where it's from and why it happened.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
