Oil Pan Leak
PostPosted: Fri Jun 18, 2010 1:35 am    Post subject: Oil Pan Leak Reply with quote
It looks like I have a slight drip coming off the front of my motor, in the area of the rubber portion of the oil pan gasket.
Has anyone else had problems here? Any suggestions?
TIA
rasta
PostPosted: Fri Jun 18, 2010 2:58 am    Post subject: Reply with quote
Permatex RTV gasket material (comes in a tube) on all corners of a pan gasket, always.
78 924 NA
5-lug
PostPosted: Fri Jun 18, 2010 5:43 am    Post subject: Reply with quote
Torque the bolts properly (as in not much!) and see if that solves the problem.
PostPosted: Fri Jun 18, 2010 10:34 am    Post subject: Reply with quote
yea ive used sealent here on the front on both sides the rubber placement can be tricky..if you let it.. try doin it upside down
with the motor in..easy fix though.
Min
PostPosted: Fri Jun 18, 2010 10:38 am    Post subject: Reply with quote
RTV is an adhesive, and unless you get exactly the correct type, it also gets eaten by synthetic fluids. So I don't recommend you glue your pan and gasket on.
Use hylomar, it seals, and isn't an adhesive so that you don't need a crowbar to remove your oilpan later.
Min
PostPosted: Mon Jun 21, 2010 5:00 pm    Post subject: Reply with quote
Hylomar is the stuff though a little clear rtv, will stop the leak.
PostPosted: Tue Jun 22, 2010 12:42 am    Post subject: Reply with quote
Fugg it, pan coming back off.
