IROCZ
Posted: Sat Jun 19, 2010 11:38 am Post subject: engine timing |
as l put in timing my car porsche 924 turbo 1981 sorry my english _________________ 924 TURBO 1981 |
Scorpio
Posted: Sat Jun 19, 2010 11:58 am Post subject: |
 _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Sat Jun 19, 2010 12:34 pm Post subject: |
Eso es difícil de entender.
Probar este traductor.
http://translate.google.com _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
Posted: Sat Jun 19, 2010 8:50 pm Post subject: |
Maybe you put too much timing in...? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Sun Jun 20, 2010 1:41 am Post subject: |
Timing is not adjustable on 1981 924 turbos. Its controlled by the DITC unit. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Martijnus
Posted: Sun Jun 20, 2010 6:25 am Post subject: |
| Nein37 wrote: | | Timing is not adjustable on 1981 924 turbos. Its controlled by the DITC unit. |
I thought the DITC only controlled the ignition timing... but apparently also the cam timing?
I'll explain in short how to time the cam:
on your marks
get set
GO! _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Sun Jun 20, 2010 8:13 am Post subject: |
Give the guy a break. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Jun 20, 2010 9:44 pm Post subject: |
Si puede explicar la problema en espanol, es posible que yo podere traducir a ingles. _________________ Mike
Martijnus
Posted: Mon Jun 21, 2010 12:32 am Post subject: |
| MikeJinCO wrote: | | Si puede explicar la problema en espanol, es posible que yo podere traducir a ingles. |
I don't speak spanish, but I can understand this perfectly  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
