simsport
Posted: Wed Jul 28, 2010 6:12 am Post subject: new cheap mod for gearbox mounts |
Well perhaps not new but an idea I came up with to uprate the gearbox mounts on the 944 Audi type box.
I have a 944S2 gearbox but I have a 1978 NA shell so the single overhead mount isnt an option and I had to use the pair of rubber/metal hangers.
However the problem is that under fast starts the mounts bounce around.
To uprate them I noted that the rubber portions have voids in the corners. What I did was get some thin wall tube and pressed short lengths into a more oval shape to fit the voids snugly. Once I had pressed them into place I added some tie-wraps in case they came free under use.
I used the car at a sprint event at Castle Coomb England and the box was held steady and the tubes stayed put just fine.
Just thought I'd pas it on.
cheers
simon _________________ Blown is always best! |
Posted: Wed Jul 28, 2010 6:32 am Post subject: |
Spec 944 guys also inject those passages with hardening silicone for the same reason. _________________ Toofah King Bad
