Brake Positive pressure (air only) bleeding question
Patrick
PostPosted: Wed Sep 22, 2010 12:45 pm    Post subject: Brake Positive pressure (air only) bleeding question Reply with quote
Hi All!
I was in the process of bleeding my brakes on my 79 NA 924 using a Positive pressure (air only) bleeder cap with 15 psi, when brake fluid started leaking out of the 2 rubber grommets that attach the brake fluid reservoir to the master cylinder when pressurizing the reservoir (presumably because its old).
Inspite of the leak, there was a steady flow of brake fluid exiting the bleeder valve, so i guess that means that there is enough air pressure anyway. Lightly pressing on the reservoir practically eliminated the leaks (which is probably what i should ask someone to do while i`m bleeding, still easier to do, than pumping on the brake pedal)
Can i safely assume anyway that since this is a positive pressure bleeder, that no air would get into the system inspite of the leaks at the 2 rubber grommets?
THANKS!
patrick
1979 924 U.S. version
Single sidedraft Weber 40
CorsePerVita
PostPosted: Wed Sep 22, 2010 12:55 pm    Post subject: Reply with quote
You shouldn't have leaks in the system with power bleeding on 15psi. If your brake system is leaking anywhere, i'd replace the part.
You can get by with a simple wiring fix when wires are old. You can get by with cheap fixes on airboxes. Even do easy cheesy fixes when something looks bad and spraypaint it.
But with brakes, your life depends on it every time you step on that pedal. If you're having to question the integrity of the braking system, then you know the answer to that question. If something is screaming "not normal" on brakes, i'd replace it.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Wed Sep 22, 2010 1:21 pm    Post subject: Reply with quote
at a little more than 15psi, I have seen the reservoir pop off the master and land on the floor...
3 928s,
CorsePerVita
PostPosted: Wed Sep 22, 2010 1:28 pm    Post subject: Reply with quote
LOL that would be entertaining. I run about 10-13 in mine, but have never seen anything leak at 15psi
- 1999 Ducati 900SS
Patrick
PostPosted: Wed Sep 22, 2010 1:53 pm    Post subject: Reply with quote
CORSEPERVITA-
Yes i agree with you.
Normally i would replace or repair any leaking part (which entails having to import them from the U.S.) I was planning to replace those rubber grommets, just that in this little country of mine, you never know what you`l find or what you wont find (wont find applies especially to the 924)
So i would rather have the new rubber grommets with me before taking out the reservoir in case the grommets get totally ruined.
I wanted to take a chance with the old ones since the leak only occurred when pressurizing the reservoir, otherwise no leaks when its the master cylinder pumping the fluid out.
I will try to locate those grommets all the same.
CorsePerVita
PostPosted: Wed Sep 22, 2010 1:57 pm    Post subject: Reply with quote
Makes sense, I just looked at the location, didn't realize it! Best of luck finding those parts!
- 1999 Ducati 900SS
Patrick
PostPosted: Wed Sep 22, 2010 2:17 pm    Post subject: Reply with quote
Thanks!
Slam
PostPosted: Fri Sep 24, 2010 2:15 am    Post subject: Reply with quote
Just did my 944 at 15 lbs. There should be no leaks, as Corse said. Of course, I did this after changing the clutch slave, only to find the clutch master seeping in the cabin. I believe Performance Products has those master cylinder grommets.
Patrick
PostPosted: Sat Oct 09, 2010 6:12 pm    Post subject: Reply with quote
I finally replaced the rubber grommets with aftermarket VW grommets and used 20 psi air with no leaks.
