tranny torque
germ924
PostPosted: Fri Oct 08, 2010 12:29 pm    Post subject: tranny torque Reply with quote
i have a i beleive came from a 924s.
does anyone know how much torque and/or horsepower it can handle.
im looking to do a 350 swap. does my drive shaft have ujoints in the torque tube..
CorsePerVita
PostPosted: Fri Oct 08, 2010 2:32 pm    Post subject: Reply with quote
there are no u joints in a torque tube. It is mated via splines and held together by clamps that mate it to your transmission, and also at the other in holding to the clutch.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Fri Oct 08, 2010 3:01 pm    Post subject: Reply with quote
Check the diameter of the shaft or count the splines. Tell use what you come up with and we'll tell you what you have.
The 924S and 944NA shared TT central shafts (the TT outer shells were mostly the same across the board, depending on the transaxle used in the back)
http://porschehybrids.pbworks.com/
Has a ton more info on V8 swaps into the 924/944 chassis.
