Brake warning light in ceter console is on constantly.. why?
turboquattro
PostPosted: Sat Oct 09, 2010 12:19 am    Post subject: Brake warning light in ceter console is on constantly.. why? Reply with quote
I've just completed a 5-bolt swap, all is well except for the brake warnign light in the centre console that won't go out anymore.
I did not touch the MC other than fill it up with fluid after all the bleeding with new calipers. It is topped up.
Hand brake all functioning.. there is no fluid level sensor that I can see and obviously on a 1980 there were not pad sensors either.
Anyone can tell me what that particular light is on for and maybe a wiring diagram so I can check what has gone wrong?
Thank you!
Martin Pajak
1985 Audi Ur-quattro
1986 Mercedes 300GD
1988 Porsche 911 RoW
1993 Audi 80 quattro avant 2.5TDI
PostPosted: Sat Oct 09, 2010 1:16 am    Post subject: Reply with quote
I (or you/anyone else) would have to verify if this applies to pre-'81, but I know for '81-up, the low oil pressure warning circuit is tied in with that brake light. -So, both brake problems, and low oil pressure will cause that light to glow.
Possibly done as a backup for the other low oil pressure light..
turboquattro
PostPosted: Sat Oct 09, 2010 3:26 am    Post subject: Reply with quote
Thanks for the tip, but it does have oil press via press gauge and the dummy light in the gauge panel goes out once engine is started.
Any other tips?
Thanks in advance.
Cheers
Martin Pajak
1986 Mercedes 300GD
PostPosted: Sat Oct 09, 2010 5:35 am    Post subject: Reply with quote
Check the hand brake electric connection gizmo, mine needs 'adjusting' on a frequent basis. I'm sure it's loose on mine, winter project. Or, you have exposed foil on the firewall hitting the oil pressure gauge wires.
President
Proscrastinators Club of Wisconsin
D Hook
PostPosted: Sat Oct 09, 2010 11:03 am    Post subject: Reply with quote
President
Dave got it right. There's a switch below the arm of the E-brake handle that is engaged when you drop the handle. If a wire comes off the switch, the light will stay on. Mine used to fall off occasionaly 'till I took some pliars and tightened the spade.
Yes, I called it a spade. I always call a spade a spade.
'80 924 n/a SOLD
Tiny
PostPosted: Tue Oct 12, 2010 3:03 am    Post subject: Reply with quote
I have a "brake" light and also an "emergency brake" light in the centre console. One is directly above the other.
Hmmm I know there are a few variants on this setup out there, but mine is a Euro. How is yours?
Is it the Emergency brake light you have lighting up? (then check the E-brake spade connector)
If it is just the "brake" light, then it is as smoothie says.
hope that helps
tiny
turboquattro
PostPosted: Tue Oct 12, 2010 8:27 am    Post subject: Reply with quote
D Hook wrote:
President
Nope, wire is perfect and on there, also I know that is working because the dummy light in the cluster (below oil light and above low fuel warning) lights up with handbrake leaver on and goes out with lever down.
The one in centre console is on all the time.
Martin Pajak
1986 Mercedes 300GD
Harm
PostPosted: Tue Oct 12, 2010 9:56 am    Post subject: Re: Brake warning light in ceter console is on constantly.. Reply with quote
turboquattro wrote:
… It is topped up.
Electrical Diagrams @ pelican. See part three.
Once, in my case, an 82 NA, it was the Brake Fluid Switch in the brake fluid reservoir
(cap on top) that got pushed in and got stuck, so it didn't show the reservoir was
filled up right and triggered the red alarm light in the center console.
Secondly when my oil level/pressure is low it wil make me aware of it when it occurs.
(Avoid that! …solved by replacing the engine )
HTH
Regards, Harm.
