moorepower
Joined: 21 Dec 2006 Posts: 263 Location: Raleigh, North Carolina, USA
Posted: Tue Oct 19, 2010 6:39 am Post subject: Identifying Early '77 Cylinder Head |
I read in a Jim Pasha article somewhere that you can identify an early ('76, early '77) cylinder head by the shape of the exhaust ports exiting the head. Early is supposed to have a flat spot at the top of the port, and later has a totally round port. Is this correct? _________________ Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways |
Posted: Tue Oct 19, 2010 9:29 am Post subject: |
I just took that pic of my ’76 head that sit in the garage and you can see the flat spot at the top.
 _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Posted: Tue Oct 19, 2010 11:16 am Post subject: |
I think the later heads have the same flat spot, so I don't think that ID's it. Check the valve size. Don't the really early heads have smaller valves? Also, probably a different casting/part #. Besides, I think they're unusual to run a-x, so most of what you'd see out there is the later style.
Edit: I just checked a few downstairs. All the n/a's have the half-rounded ports, all the turbos are round (no surprise, many of them have the ring inserts...) |
moorepower
Posted: Wed Oct 20, 2010 10:05 am Post subject: |
I checked valve sizes, and I have 40mm intake/33mm exhaust. So I guess it is a '77.5+ head.
It's a good thing, because I was about to push this car into the lake. I'm down to my last straw with this thing.  _________________ Dan.
