staticsan
Posted: Fri Oct 22, 2010 8:28 am Post subject: |
He needs a mount for the camera. Hand-held doesn't really cut it for the driving shots.
Interesting to observe that although a 911 body-shape will always be Very Nice, I find the rear-view of the 924 is still far superior to the Cayman.
Wade. |
Posted: Fri Oct 22, 2010 10:55 am Post subject: |
yes, I agree.
But look at the engine bay. Does anyone else notice something odd here? _________________ 3 928s, |
Posted: Fri Oct 22, 2010 1:09 pm Post subject: |
emoore924's car is popular these days...
He lists the mod's, and there's a few of 'em. I guess it depends how you define "odd"?
But you got me, what's piqued your interest? _________________ '80 924 Turbo |
tomcooper
Joined: 17 Feb 2004 Posts: 301 Location: Waterloo, Nebraska
Posted: Fri Oct 22, 2010 1:38 pm Post subject: |
I would guess that I would have to question where the turbo is mounted. The charge tube has been modified and the nice shiny piece added.
Tom _________________ Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab |
staticsan
Posted: Fri Oct 22, 2010 2:54 pm Post subject: |
It looks too long. They've re-routed the turbo's output to somehow come up behind the right headlight.
Maybe there's an intercooler after the turbo that we can't see.
Wade. |
Posted: Fri Oct 22, 2010 3:38 pm Post subject: |
it must be too long since I have worked on these cars, and I must have been tired. HAHA
It had appeared at first glance to me that he was doing a blow through design on the CIS distributor instead of the suck through design that is stock.
Someone should do that though. It would simplify the plumbing greatly. _________________ 3 928s, |
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Oct 23, 2010 1:39 am Post subject: |
| staticsan wrote: | It looks too long. They've re-routed the turbo's output to somehow come up behind the right headlight.
Wade. |
The air/water intercooler is staring you in the face at the 0:27 second mark in the video (letters PWR on it). There would be a heat exchanger elsewhere and a small circulation water/coolant pump to push water/coolant through the small black hoses leading to/from the intercooler.
| Lizard wrote: | it must be too long since I have worked on these cars, and I must have been tired. HAHA
Someone should do that though. It would simplify the plumbing greatly. |
Blow through on a CIS wouldn't be any advantage at all, the pressure difference being after the turbo would blow the plate wide open every time boost hit. If you want to upgrade a CIS car to simplify plumbing, ditch the CIS and go EFI. The tube you see going into the airbox just feeds cooler outside air into the airbox instead of drawing in under hood air like stock. _________________ '80 924 Turbo - SOLD!
Porscheless  |
Posted: Sat Oct 23, 2010 5:52 am Post subject: |
You are wrong on the blow through.
There have been a few people who have done blow through designs and they have worked fine.
I would agree that the plate would be pushed wide open if it was simply a void behind it. But because it is a closed space. It will still measure air correctly as the engine is only going to allow as much as at it can use to move, and thus move the plate. _________________ 3 928s, |
Posted: Sat Oct 23, 2010 12:34 pm Post subject: |
Was wondering where the engine bay shot was. That vids a classic
I like it.. | bnoon wrote: | | staticsan wrote: | It looks too long. They've re-routed the turbo's output to somehow come up behind the right headlight.
Wade. |
Blow through on a CIS wouldn't be any advantage at all, the pressure difference being after the turbo would blow the plate wide open every time boost hit. If you want to upgrade a CIS car to simplify plumbing, ditch the CIS and go EFI. The tube you see going into the airbox just feeds cooler outside air into the airbox instead of drawing in under hood air like stock. |
_________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
joejax
Posted: Sat Oct 23, 2010 12:39 pm Post subject: |
Hey Joe, did you see that squirrel sitting in the engine bay too?
It's kinda right in the middle near the back, reminds me of a funny story...  _________________ I got nothin'
Uhhh...you got any pics? |
staticsan
Posted: Sun Oct 24, 2010 6:21 am Post subject: |
[quote="bnoon"]
Of course! I just hadn't seen it like that before!
Wade. |
bnoon
Posted: Sun Oct 24, 2010 8:39 am Post subject: |
| staticsan wrote: | | bnoon wrote: |
The air/water intercooler is staring you in the face at the 0:27 second mark in the video (letters PWR on it). There would be a heat exchanger elsewhere and a small circulation water/coolant pump to push water/coolant through the small black hoses leading to/from the intercooler. |
Wade. |
Yeah, the "inline" core layouts aren't that popular and are usually quite expensive compared to other core designs. I've used cores from frozenboost and cxracing in past projects and plan to do so again on my 931. _________________ '80 924 Turbo - SOLD!
Porscheless  |
dpw928
Posted: Mon Oct 25, 2010 10:01 am Post subject: |
| Lizard wrote: | You are wrong on the blow through.
I would agree that the plate would be pushed wide open if it was simply a void behind it. But because it is a closed space. It will still measure air correctly as the engine is only going to allow as much as at it can use to move, and thus move the plate. |
Agree about the plate but the pressure from boost in the plenum can cause a counter force on the piston in the distributor and affect the A/F mixture. The ones I have seen plumbed this way had a high A/F mixture when under boost. This was on a 928 which didn't have a frequency valve/O2 adjustment, so a later 924 may be able to adjust.
78 928 5 sp Silver
78 928 AT Euro Black |
