Forte420
Posted: Wed Jan 19, 2011 6:58 am Post subject: 30k on timing belt.. replace or not? |
Hi all,
Just got an '87 924S which had lots of service records that came with it.
The last time the timing belt was changed was at 60k, and was retensioned ~1500 miles later. It currently has ~88k on it, and a retension was not done at 75k. Most sites I've seen has a change interval of 45k, but a retension every 15k.
Should the belt be replaced or just re-tensioned? I don't want to drop 1 grand right now if I just need to buy the retensioning tool.
Thanks for the help. |
joecitizennn
Posted: Wed Jan 19, 2011 10:55 am Post subject: |
It is important to also know how many years since the belt was replaced. As a new owner I would put changing the belts on the top of my list regardless what records say. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Forte420
Posted: Wed Jan 19, 2011 11:36 am Post subject: |
The belts are 4 years old, so I'll change them anyway.
Does Pelican Parts have just about the cheapest OEM parts out there? For a water pump, belts/rollers/tensioners, front engine seals, ignition rotor, plugs, cap and the 920x tool, it came out to about 970. Is that pretty reasonable?
Also, here she is:
joecitizennn
Posted: Wed Jan 19, 2011 11:54 am Post subject: |
You need ignition parts as well? I see no mention of spark plug wires.
I sourced my belt and roller kit, water pump and tensioning tool for 350. The belt kit was contitech and the waterpump was a rebuilt OE. Both came from ebay. The tensioning tool came from 44andmoreparts.com.
I have done 11 timing belt jobs in the last 5 years with that tool with no problems. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
bcblase
Posted: Wed Jan 19, 2011 11:20 pm Post subject: |
Paragon Products has a good selection of OE parts at reasonable prices.
Arnnworx is a good place to get the 944-specific tools, including the timing belt tools.
IMHO, eBay is OK if you know exactly what the seller is offering, but be careful about what you are buying. If the part is a well known brand or OEM supplier, you should be OK. _________________ 1987 Porsche 924S - track toy
joecitizennn
Posted: Thu Jan 20, 2011 10:29 am Post subject: |
| bcblase wrote: | | eBay is OK if you know exactly what the seller is offering, but be careful about what you are buying. If the part is a well known brand or OEM supplier, you should be OK. |
That reminds me, today I pulled the front camshaft seal out of my 924s because it has started to leak. The seal was bought from Napa, it is the only seal on my engine bought from Napa. When I resealed my engine two years ago I used a german seal kit bought from ebay, but I somehow came up short a cam seal. and in a rush to get things together bought one from Napa. It is now as hard as a rock and cracking around the lip. Not buying any more seals from Napa. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
bcblase
Posted: Fri Jan 21, 2011 7:52 am Post subject: |
The German OEM stuff is usually best - but I did buy a 944 timing belt from a friend that used to own a 944, and had an "extra" on the shelf - he didn't tell me it had been "on the shelf" since 1995 - it was hard as a rock also.
Brad _________________ 1987 Porsche 924S - track toy
joecitizennn
Posted: Mon Jan 24, 2011 2:36 am Post subject: |
went through several wrong sized seals from autozone till they got it close to right. The seal they provided me was 1mm wider than the oe, but the id and od were spec. When pressed in place everything cleared. Will have to wait another 2 years to see if this seal is worth a crap. meanwhile my other german sourced seals just keep on sealing... _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
